OSPF Neibourship formation on secondary IP
rohit.kulkarni
Hi Friends, Just stuck with query in discussion. Please let me know if any one can sort me out.
I have two routers connected on serial link with /24 subnet mask, I have configured primary ip on WAN as 192.168.1.1/24 on R1 and  .2 /24 on R2
While at the same time i do assign .3/24 as secondary ip on same interface on R1 and .4/24 on R2.
Now i advertise this subnet in OSPF, so now my query is OSPF will form neigbourship with primary IP or with secondary ip or with Both
            R1       ===>  R2
192.168.1.1/24  ==> 192.168.1.2 /24
192.168.1.3/24  ==>  192.168.1.4 /24
David Aicher
It will not form a relationship with the secondary address.  It is not possible to configure it to do so.
http://www.cisco.com/en/US//tech/tk365/technologies_tech_note09186a0080094050.shtml
That said I am unsure of the reason you need two addresses in the same subnet on the same interface.   Maybe you could explain the reason for doing this?
Dave Aicher
In addition to david...you can announce secondary ip in ospf but adjancency will not form. In your case both primary/secondary is having
same subnet (strange, i have seed for the first time) so nothing different. But if you have different subnet you will be able to announce via ospf
regards
mahesh
