OSPF not sending v6 default-route - Cant figure out why.
graham smart
Hi Guys,
I have two routers , One in area0/1 and one in area1
The router in area1 doesnt seem to be getting a default route from the router in area0/1
RouterB ( A juniper E120 ) has a neighbor relationship and gets other routes but refuses to recieve a default..
Im a little stuck how to troubleshoot. Ive checked the config and other devices seem to get a default ::0 but this routerB refuses to ( Even though the configuration appears identicle? How can I verify that the cisco RouterA is indeed advertising a ipv6 default?
For simplicity..
Here is how its setup..
RouterB(Area1)--------------------------------RouterA(Area 0/1)--------> Net
RouterA has a default in its table.
sh ipv6 route ::/0
Routing entry for ::/0
  Known via "ospf 7", distance 110, metric 2005
  Tag 7, type extern 1
... Etc
RouterA config:
ipv6 router ospf 7
log-adjacency-changes
auto-cost reference-bandwidth 100000
area 1 stub
default-information originate metric 2000 metric-type 1
passive-interface default
no passive-interface TenGigabitEthernet2/3
no passive-interface TenGigabitEthernet3/2
no passive-interface GigabitEthernet9/47
no passive-interface Port-channel3
no passive-interface Vlan200
-Graham
Please note: My comments are simply suggestions. I cannot be held liable for any loss of data, life or marbles due to following my instructions.
Got a website? Need some live chat software?
Graham,
Well, it may be a glitch in Juniper's OSPF implementation - is it possible for you to restart the OSPF process on the RouterB, or perhaps restart the entire router?
Nevertheless, we may be dealing with some JUNOS specific behavior. What is the exact version? Although I am not acquainted with Juniper devices, this may be a good reason to start I may try to look up specifics about default routes in your JUNOS version.
Best regards,
Peter
11 Replies 11
Peter Paluch
Hi Graham,
Hey, we're meeting again
You have an interesting problem here. Just wondering: as the Area 1 is configured as stub, the default route should be injected into it by RouterA automatically, without actually needing the default-information originate command. Its presence should actually not influence the Area 1 at all, because it results in originating LSA-5 which is not allowed in stubby areas.
A couple of questions:
  • What does show ipv6 ospf neighbor command say on RouterB?
  • What does the show ipv6 ospf summary 0.0.0.0 say on both RouterB and RouterA?
Best regards,
Peter
Hey again
Im looking into a fairly badly implemented v6 network and its got some of the oddest problems ive never come across before
Anyway, Hope this helps?
RouterA ( Both routers connect to each other via a vlan interface )
sh ipv6 ospf neighbor | inc 95.163
xxx.125.95.163    1   FULL/BDR        00:00:07    838860810       Vlan200
#show ipv6 ospf summary 0.0.0.0
% Invalid input detected at '^' marker.
OSPFv3 Process 7, Summary-prefix
    Not configured
RouterB
sh ipv6 ospf neighbors
Neighbor ID     Pri  State            Dead Time Intf ID     Interface
xxx.125.95.30   1    FULL/DR          00:00:07  0x68 GigabitEthernet1/0/0
-Graham
Hello Graham,
Oh, I apologize about the typo in the command. It should read:
show ipv6 ospf database inter-area
Sorry! I'm still thinking too much IPv4...
Best regards,
Peter
Its ok the difference with v4 and v6 commands are slowly driving me insane.
RouterA: xxx.125.95.30
RouterB: xxx.125.95.163
Anyway..
% Incomplete command.
Not sure what your after, So heres something:
show ipv6 ospf database inter-area prefix ::/0
            OSPFv3 Router with ID (XXX.125.95.30) (Process ID 7)
                Inter Area Prefix Link States (Area 1)
  LS age: 1301
  LS Type: Inter Area Prefix Links
  Link State ID: 0
  Advertising Router: xxx.125.95.30
  LS Seq Number: 80006EBE
  Checksum: 0x2F13
  Length: 28
  Metric: 1
  Prefix Address: ::
  Prefix Length: 0, Options: None
  LS age: 326
  Link State ID: 0
  Advertising Router: xxx.212.125.95.47
  LS Seq Number: 80001515
  Checksum: 0x280C
  Length: 28
  Metric: 1
  Prefix Address: ::
(JE120) ( RouterB )
show ipv6 ospf database intra-area-prefix
      V3 Intra Area Prefix Link States (Area 0.0.0.1)
  LS age: 1394
  LS Type: Intra Area Prefix Links
  Link State ID: 0.1.160.0
  Advertising Router: XXX.125.95.30
  LS Seq Number: 0x8000085b
  Checksum: 0x6243
  Length: 44
  Numer of Prefixes 1
  Referenced LSA Type 0x    2002
  Referenced LSA Advertising Router XXX.125.95.30
  Referenced LSA ID 104
  Prefixes
       XXXX:ed0:0:b:: / 64       options 0       metric 0
  LS age: 3600
  Link State ID: 0.0.0.1
  Advertising Router: XXX.125.95.163
  LS Seq Number: 0x800073f3
  Checksum: 0x7517
  Length: 64
  Numer of Prefixes 2
  Referenced LSA Type 0x    2001
  Referenced LSA Advertising Router XXX.125.95.163
  Referenced LSA ID 0
  Prefixes
       XXXX:ed0::f / 128       options 2       metric 0
       XXXX:ed0:0:b:: / 64       options 0       metric 100
  LS age: 3600
  Link State ID: 0.0.0.8
  LS Seq Number: 0x80000007
  Checksum: 0x6957
  Length: 44
  Numer of Prefixes 1
  Referenced LSA ID 838860807
  Prefixes
       XXXX:ed0:0:a:: / 64       options 0       metric 0
  LS age: 2230
  Link State ID: 0.0.0.11
  LS Seq Number: 0x80005290
  Checksum: 0x7964
  Length: 44
  Numer of Prefixes 1
  Referenced LSA ID 838860810
  Prefixes
-Graham
Hello Graham,
Basically, I want to find out if the default route has been sent into the Area1 as LSA-3.
On a quick topology I've concocted to test OSPFv3, I see the following output on my wannabe-RouterB:
R3#show ipv6 ospf database inter-area prefix ::/0
            OSPFv3 Router with ID (3.3.3.3) (Process ID 1)
  Routing Bit Set on this LSA
  LS age: 120
  Link State ID: 2
  Advertising Router: 2.2.2.2
  LS Seq Number: 80000001
  Checksum: 0x5DD6
  Length: 28
  Metric: 1
  Prefix Address: ::
Using the same command on your RouterB, do you see any LSA referring to the ::/0 being present?
Best regards,
Peter
Annoyingly the routerb is a damn Juniper E120. So that command isnt available. I cant even find a similar one
Grr.
show ipv6 ospf database ?
  &>                 Display and redirect the output to a file, replacing
                     previous contents
  &>>                Display and redirect the output to a file, appending to
                     previous contents
  >                  Redirect the output to a file, replacing previous contents
  >>                 Redirect the output to a file, appending to previous
                     contents
  database-summary   Display summary of the OSPFv3 link state database
  external           Display V3 external link state
  grace              Display V3 grace link state
  inter-area-net     Display V3 inter-area network link state
  inter-area-router  Display V3 inter-area asbr link state
  intra-area-prefix  Display V3 intra area prefix link states
  link               Display V3 Link link states
  network            Display V3 Network link states
  router             Display V3 router link states
  vrf                Specify a VRF as the context for this command
  |                  Filter output using the CLI Filtering feature
lon029#show ipv6 ospf database inter
lon029#show ipv6 ospf database inter-area-n
lon029#show ipv6 ospf database inter-area-net ?
  &>       Display and redirect the output to a file, replacing previous
           contents
  &>>      Display and redirect the output to a file, appending to previous
           contents
  >>       Redirect the output to a file, appending to previous contents
  A.B.C.D  Advertising router
Done know if this helps?
-G
[code]
lon029#show ipv6 ospf database inter-area-net xxx.125.95.30
      V3 Inter-Area-Net Link States (Area 0.0.0.1)
  LS age: 1431
  LS Type: Inter Area Net Links
  Link State ID: 0.0.0.0
  LS Seq Number: 0x80006ebf
  Checksum: 0x2d14
  Length: 28
     Metric: 1
       :: / 0       options 0       metric 0
  LS age: 1431
  LS Seq Number: 0x80001655
  Checksum: 0xff75
  Length: 44
     Metric: 1000
       2a00:ed0::9 / 128       options 0       metric 0
  LS age: 1431
  Link State ID: 0.0.0.19
  LS Seq Number: 0x8000163f
  Checksum: 0x224b
  Length: 44
     Metric: 0
       2a00:ed0::1 / 128       options 0       metric 0
  LS age: 1436
  Link State ID: 0.0.0.20
  Checksum: 0x6118
  Length: 44
     Metric: 1000
       2a00:ed0:0:1::30 / 126       options 0       metric 0
  LS age: 1436
  Link State ID: 0.0.0.21
  Checksum: 0x 9e0
  Length: 36
     Metric: 1000
       2a00:ed0:0:6:: / 64       options 0       metric 0
  LS age: 1436
  Link State ID: 0.0.3.59
  LS Seq Number: 0x8000151a
  Checksum: 0xc587
  Length: 44
     Metric: 1005
       2a00:ed0:0:1::2c / 126       options 0       metric 0
  LS age: 1436
  Link State ID: 0.0.3.60
  Checksum: 0xea76
  Length: 44
     Metric: 5
       2a00:ed0::2 / 128       options 0       metric 0
  LS age: 1437
  Link State ID: 0.0.3.61
  LS Seq Number: 0x80001513
  Checksum: 0xbeab
  Length: 44
     Metric: 5
       2a00:ed0:0:1:: / 126       options 0       metric 0
  LS age: 1437
  Link State ID: 0.0.3.143
  LS Seq Number: 0x8000116b
  Checksum: 0xbceb
  Length: 44
     Metric: 15
       2a00:ed0::10 / 128       options 0       metric 0
  LS age: 1437
  Link State ID: 0.0.3.144
  Checksum: 0xfc57
  Length: 44
     Metric: 1115
       2a00:ed0:0:1::14 / 126       options 0       metric 0
  LS age: 1437
  Link State ID: 0.0.3.145
  Checksum: 0xe369
  Length: 44
     Metric: 115
       2a00:ed0::5 / 128       options 0       metric 0
  LS age: 1438
  Link State ID: 0.0.3.146
  Checksum: 0x9041
  Length: 44
     Metric: 215
       2a00:ed0:0:1::1c / 126       options 0       metric 0
  LS age: 1438
  Link State ID: 0.0.3.147
  Checksum: 0x1eb6
  Length: 44
     Metric: 215
       2a00:ed0:0:1::18 / 126       options 0       metric 0
  LS age: 1438
  Link State ID: 0.0.3.148
  Checksum: 0x1818
  Length: 44
     Metric: 1115
       2a00:ed0:0:1::34 / 126       options 0       metric 0
  LS age: 1438
  Link State ID: 0.0.3.149
  Checksum: 0xde60
  Length: 44
     Metric: 115
       2a00:ed0:0:1::10 / 126       options 0       metric 0
  LS age: 1438
  Link State ID: 0.0.3.150
  Checksum: 0xd0f8
  Length: 44
     Metric: 215
       2a00:ed0:0:1::20 / 126       options 0       metric 0
  LS age: 1439
  Link State ID: 0.0.3.151
  Checksum: 0x1cc5
  Length: 44
     Metric: 215
       2a00:ed0::6 / 128       options 0       metric 0
  LS age: 1439
  Link State ID: 0.0.3.152
  Checksum: 0xb211
  Length: 44
     Metric: 1215
       2a00:ed0:0:1::38 / 126       options 0       metric 0
  LS age: 1439
  Link State ID: 0.0.3.153
  Checksum: 0xdc7d
  Length: 44
     Metric: 315
       2a00:ed0:0:1::28 / 126       options 0       metric 0
  LS age: 1439
  Link State ID: 0.0.3.154
  Checksum: 0x6af2
  Length: 44
     Metric: 315
       2a00:ed0:0:1::24 / 126       options 0       metric 0
  LS age: 1439
  Link State ID: 0.0.3.155
  Checksum: 0xeed7
  Length: 36
     Metric: 315
       2a00:ed0:1:: / 64       options 0       metric 0
  LS age: 1439
  Link State ID: 0.0.3.156
  Checksum: 0xf6cd
  Length: 36
     Metric: 315
       2a00:ed0:1:1:: / 64       options 0       metric 0
  LS age: 1439
  Link State ID: 0.0.3.157
  Checksum: 0xfec3
  Length: 36
     Metric: 315
       2a00:ed0:1:2:: / 64       options 0       metric 0
  LS age: 1439
  Link State ID: 0.0.3.158
  Checksum: 0x45f2
  Length: 36
     Metric: 1215
       2a00:ed0:0:5:: / 64       options 0       metric 0
  LS age: 1439
  Link State ID: 0.0.3.159
  Checksum: 0xe5f2
  Length: 44
     Metric: 215
       2a00:ed0::7 / 128       options 0       metric 0
  LS age: 1439
  Link State ID: 0.0.3.160
  Checksum: 0x67cb
  Length: 36
     Metric: 1215
       2a00:ed0:0:8:: / 64       options 0       metric 0
  LS age: 1439
  Link State ID: 0.0.3.161
  Checksum: 0xebe9
  Length: 44
     Metric: 215
       2a00:ed0::8 / 128       options 0       metric 0
  LS age: 1440
  Link State ID: 0.0.3.162
  Checksum: 0x59f0
  Length: 44
     Metric: 1115
       2a00:ed0::b / 128       options 0       metric 0
  LS age: 1440
  Link State ID: 0.0.3.164
  Checksum: 0x797f
  Length: 36
     Metric: 1015
       2a00:ed0:0:7:: / 64       options 0       metric 0
  LS age: 1440
  Link State ID: 0.0.3.165
  LS Seq Number: 0x8000106c
  Checksum: 0x878e
  Length: 36
     Metric: 1215
       2a00:ed0:2000:: / 64       options 0       metric 0
  LS age: 1440
  Link State ID: 0.0.3.167
  LS Seq Number: 0x80001036
  Checksum: 0xc711
  Length: 44
     Metric: 10
       2a00:ed0::3 / 128       options 0       metric 0
  LS age: 1440
  Link State ID: 0.0.3.168
  Checksum: 0x448f
  Length: 44
     Metric: 10
       2a00:ed0:0:1::8 / 126       options 0       metric 0
  LS age: 1440
  Link State ID: 0.0.3.169
  Checksum: 0xefe1
  Length: 44
     Metric: 15
       2a00:ed0:0:1::4 / 126       options 0       metric 0
  LS age: 1440
  Link State ID: 0.0.3.172
  LS Seq Number: 0x80000aa6
  Checksum: 0xd388
  Length: 44
     Metric: 15
       2a00:ed0:0:1::c / 126       options 0       metric 0
  LS age: 1440
  Link State ID: 0.0.3.186
  LS Seq Number: 0x8000070b
  Checksum: 0xbd11
  Length: 36
[/code]
-Graham
Hi Graham,
Well, the LSA-3 containing the ::/0 seems definitely to be present there. Hmm, and what does the show ipv6 route or similar say? Is there really no default route present?
Best regards,
Peter
Yep, Its reallllly odd. Its as if the router is just deciing to not bother putting it into its routing table.
Heres the entire routing table for that router:
lon029#sh ipv6 route
Protocol/Route type codes:
  I1- ISIS level 1, I2- ISIS level2,
  I- route type intra, IA- route type inter, E- route type external,
  i- metric type internal, e- metric type external,
  O- OSPF, E1- external type 1, E2- external type2,
  N1- NSSA external type1, N2- NSSA external type2
  L- MPLS label, V- VRF, *- via indirect next-hop
         Prefix/Length             Type     Dst/Met           Interface
xx00:ed0::1/128                  O-IA      112/100    GigabitEthernet1/0/0
xx00:ed0::2/128                  O-IA      112/105    GigabitEthernet1/0/0
xx00:ed0::3/128                  O-IA      112/110    GigabitEthernet1/0/0
xx00:ed0::5/128                  O-IA      112/215    GigabitEthernet1/0/0
xx00:ed0::6/128                  O-IA      112/315    GigabitEthernet1/0/0
xx00:ed0::7/128                  O-IA      112/315    GigabitEthernet1/0/0
xx00:ed0::8/128                  O-IA      112/315    GigabitEthernet1/0/0
xx00:ed0::9/128                  O-IA      112/1100   GigabitEthernet1/0/0
xx00:ed0::b/128                  O-IA      112/1215   GigabitEthernet1/0/0
xx00:ed0::e/128                  O-IA      112/210    GigabitEthernet1/0/0
xx00:ed0::f/128                  Connect   0/0        loopback0
xx00:ed0::10/128                 O-IA      112/115    GigabitEthernet1/0/0
xx00:ed0::15/128                 O-IA      112/1215   GigabitEthernet1/0/0
xx00:ed0::3a/128                 O-IA      112/110    GigabitEthernet1/0/0
xx00:ed0::3b/128                 O-IA      112/116    GigabitEthernet1/0/0
xx00:ed0::3c/128                 O-IA      112/115    GigabitEthernet1/0/0
xx00:ed0:0:1::/126               O-IA      112/105    GigabitEthernet1/0/0
xx00:ed0:0:1::4/126              O-IA      112/115    GigabitEthernet1/0/0
xx00:ed0:0:1::8/126              O-IA      112/110    GigabitEthernet1/0/0
xx00:ed0:0:1::c/126              O-IA      112/115    GigabitEthernet1/0/0
xx00:ed0:0:1::10/126             O-IA      112/215    GigabitEthernet1/0/0
xx00:ed0:0:1::14/126             O-IA      112/1215   GigabitEthernet1/0/0
xx00:ed0:0:1::18/126             O-IA      112/315    GigabitEthernet1/0/0
xx00:ed0:0:1::1c/126             O-IA      112/315    GigabitEthernet1/0/0
xx00:ed0:0:1::20/126             O-IA      112/315    GigabitEthernet1/0/0
xx00:ed0:0:1::24/126             O-IA      112/415    GigabitEthernet1/0/0
xx00:ed0:0:1::28/126             O-IA      112/415    GigabitEthernet1/0/0
xx00:ed0:0:1::2c/126             O-IA      112/1105   GigabitEthernet1/0/0
xx00:ed0:0:1::30/126             O-IA      112/1100   GigabitEthernet1/0/0
xx00:ed0:0:1::34/126             O-IA      112/1215   GigabitEthernet1/0/0
xx00:ed0:0:1::38/126             O-IA      112/1315   GigabitEthernet1/0/0
xx00:ed0:0:1::5c/126             O-IA      112/115    GigabitEthernet1/0/0
xx00:ed0:0:1::60/126             O-IA      112/210    GigabitEthernet1/0/0
xx00:ed0:0:1::64/126             O-IA      112/116    GigabitEthernet1/0/0
xx00:ed0:0:1::78/126             O-IA      112/110    GigabitEthernet1/0/0
xx00:ed0:0:1::80/126             O-IA      112/120    GigabitEthernet1/0/0
xx00:ed0:0:1::84/126             O-IA      112/1215   GigabitEthernet1/0/0
xx00:ed0:0:5::/64                O-IA      112/1315   GigabitEthernet1/0/0
xx00:ed0:0:6::/64                O-IA      112/1100   GigabitEthernet1/0/0
xx00:ed0:0:7::/64                O-IA      112/1115   GigabitEthernet1/0/0
xx00:ed0:0:8::/64                O-IA      112/1315   GigabitEthernet1/0/0
xx00:ed0:0:a::/64                Connect   0/0        GigabitEthernet0/0/1
xx00:ed0:0:b::/64                Connect   0/0        GigabitEthernet1/0/0
xx00:ed0:0:c::/64                O-IA      112/210    GigabitEthernet1/0/0
xx00:ed0:0:d::/64                O-IA      112/215    GigabitEthernet1/0/0
xx00:ed0:1::/64                  O-IA      112/415    GigabitEthernet1/0/0
xx00:ed0:1:1::/64                O-IA      112/415    GigabitEthernet1/0/0
xx00:ed0:1:2::/64                O-IA      112/415    GigabitEthernet1/0/0
xx00:ed0:2000::/64               O-IA      112/1315   GigabitEthernet1/0/0
lon029# sh ipv6 roue
lon029# sh ipv6 rou
lon029# sh ipv6 route ::0
% Route lookup failed (no route table entry)
lon029# sh ipv6 route ::/0
-Graham
Graham,
Best regards,
Peter
Yeah im thinking the same now.
Ive found that for some reason the route isnt advertising its ipv6 loopback address to the cisco P's either.
Yet we have other E120's that work fine ( Exactly same config )
Ive raised a tac case with juniper. I did think that maybe this router was playing up and I think this confirms it.
Always good when its not a cisco issue
Thanks again for your help. Its certainly good to know now that the router IS! getting the default ::/0 but just ignoring it.
Will see if I can restart the ospfv3 service. May just reload the whole damn thing lol.
Thanks again for your swift helpful support on this matter
Have a great day.
-Graham
Hello Graham,
You are most welcome! Please keep me informed if anything new comes from Juniper that will actually help you solve this. I am interested in learning what was the root cause of this issue.
Once again, sorry for the typos in my recommended commands and for not being clear about my intention from the beginning. Anyway, it has been a pleasure!
Take care.
Best regards,
Peter
