OSPF Over DMVPN
mandeep62
Hi all, I'm trying to configure ospf over dmvpn. The data doesn't pass through the tunnel. I have attached the topology.
I have configured OSPF on R1, R2 and R3 and R2 is the hub while R3 and R1 are the spokes.
R2 Hub config:
R2#show run | section ospf
 ip ospf network broadcast
router ospf 1
 router-id 2.2.2.2
 network 10.10.20.0 0.0.0.255 area 0
 network 192.168.1.0 0.0.0.255 area 0
 network 201.1.12.0 0.0.0.255 area 0
 network 201.1.13.0 0.0.0.255 area 0
interface Tunnel0
ip address 192.168.1.2 255.255.255.0
no ip redirects
ip nhrp map multicast dynamic
ip nhrp network-id 1
tunnel source GigabitEthernet2/0
tunnel mode gre multipoint
R1 config:
R1#show run | section ospf
 ip ospf priority 0
router ospf 1
 router-id 1.1.1.1
 network 10.10.10.0 0.0.0.255 area 0
interface Tunnel0
 no ip redirects
 ip nhrp map 192.168.1.2 201.1.12.2
 ip nhrp map multicast 201.1.12.2
 ip nhrp nhs 192.168.1.2
 ip ospf priority 0
R3 config:
router ospf 1
 router-id 3.3.3.3
 network 10.10.30.0 0.0.0.255 area 0
interface Tunnel0
 ip address 192.168.1.3 255.255.255.0
 no ip redirects
 ip ospf priority 0
 tunnel source GigabitEthernet1/0
Am I doing something wrong?
7 Replies 7
Francesco Molino
If you issue show dmvpn do you see your tunnels up?
If you want to have dmvpn with spoke to spoke dynamic tunnel you need to add a router interconnecting these 3 routers R1, R2 and R3 to simulate internet.
Also in your ospf config, you added your public Network 201.x.x.x and you don't need it otherwise adjacency will be built through it and traffic will flow directly without passing through tunnels.
Make these corrections first and let us know your tunnels and dmvpn status.
If you want to take an overview of configs, go on the following Cisco documentation guide:
https://www.cisco.com/c/en/us/support/docs/security-vpn/ipsec-negotiation-ike-protocols/43068-dmvpn-gre-ospf.html
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
below is the output:
R2#show dmvpn
Interface: Tunnel0, IPv4 NHRP Details
Type:Hub, NHRP Peers:2,
# Ent Peer NBMA Addr Peer Tunnel Add State UpDn Tm Attrb
1 201.1.12.1 192.168.1.1 UP 00:14:04 D
1 201.1.13.1 192.168.1.3 UP 00:05:59 D
R1#show dmvpn
Type:Spoke, NHRP Peers:1,
1 201.1.12.2 192.168.1.2 UP 00:14:36 S
R3#show dmvpn
1 201.1.12.2 192.168.1.2 UP 00:07:00 S
R3#show ip nhrp
192.168.1.2/32 via 192.168.1.2
Tunnel0 created 00:16:51, never expire
Type: static, Flags: used
NBMA address: 201.1.12.2
R2#show ip nhrp
192.168.1.1/32 via 192.168.1.1
Tunnel0 created 00:15:51, expire 01:44:08
Type: dynamic, Flags: unique registered used
NBMA address: 201.1.12.1
192.168.1.3/32 via 192.168.1.3
Tunnel0 created 00:07:47, expire 01:52:12
NBMA address: 201.1.13.1
R1#show ip nhrp
Tunnel0 created 00:16:10, never expire
However, I created different process IDs for ospf now. one for the internal network( public) and one for the public ones.
router ospf 2
router ospf 1
router ospf 2
router ospf 1
R3#show run | section ospf
router ospf 2
router ospf 1
I don't know how to configure correctly this.
Have you removed those lines from ospf config because you don't need them:
Then what are you trying to test you said it's not working?
Francesco
Yes, I have removed them and advertised those in different OSPF ID. It's not working.
Ok. For test just remove public segments to be advertised and building an adjacency over it. Only adjacency you should have is over tunnel interfaces.
Are you testing ping from spoke vlan to hub vlan?
Can you share some outputs of traceroutes please?
Francesco
post the full configurations of your routers not just snippets, so we can lab this...
Hello
make the changes below to your routers (changes marked in bold):
R2
router ospf 1
router-id 2.2.2.2
network 10.10.20.0 0.0.0.255 area 1
network 192.168.1.0 0.0.0.255 area 1
area 1 stub no-summary
interface Tunnel0
no ip redirects
ip opsf priority 255
R1
router ospf 1
router-id 1.1.1.1
network 10.10.10.0 0.0.0.255 area 1
interface Tunnel0
no ip redirects
ip ospf priority 0
R3
router ospf 1
 router-id 3.3.3.3
 network 10.10.30.0 0.0.0.255 area 1
interface Tunnel0
 no ip redirects
 ip ospf priority 0
