OSPF over Frame Relay
limleeheng
How can I let the 2 spoke be able to ping to each other with using subinterfaces on the hub router over frame relay?
When I do "sh ip ospf neigh" there is no neighbor.
Thank you.
Ron
Hello Ron,
Frame Relay defaults OSPF network type non-broadcast, either change the OSPF network type to broadcast with the interface command 'ip ospf network broadcast', on both sides, or define neighbors on the hub, under the OSPF routing process:
Hub
router ospf 1
neighbor x.x.x.x (address of spoke 1)
neighbor x.x.x.x (address of spoke 2)
HTH,
GP
Have you got the solution for 2 spoke be able to ping to each other with using subinterfaces. As i tried one time for plotagon story download. But that was not properly working. As watched alot of videos on youtube. But that didn't worked for me. So if you have any solution for it thenk kindly do share with me.
