C927 PPPOE Router crashes
yoav-shneor
Hello everyone.
Cisco 927 VDSL with pppoe configured crushes after dialer succeed.
if I diable the logical VC , router stays synchonized and alive .
when the PPPOE dialer and connects it crushes down.
=================== script section of interface &Dialer ===============
interface Ethernet0
description -WAN$
no ip address
no sh
interface Ethernet0.101
encapsulation dot1Q 101
pppoe enable group global
pppoe-client dial-pool-number 1
interface Dialer0
mtu 1492
ip address negotiated
ip mtu 1460
encapsulation ppp
ip tcp adjust-mss 1412
dialer pool 1
ppp pap sent-username USER@DOMAIN password 0 PASSW0RD
ppp ipcp route default
7 Replies 7
yoav-shneor
router version 15.8
VDSL firmware   c900_VA_A_39x3_B_39x3_26u.bin
check crash logs , or logs ? crash mean router reboot automatically ?
check crash info :
https://www.cisco.com/c/en/us/support/docs/universal-gateways-access-servers/90-series-customer-premises-equipment/7900-crashes-router-troubleshooting.html
BB
The router reboots itself.
And we lose access to it.
So I don't really have a log to chek.
Can i find crashinfo in  FLASH or other name ?
 - Attach a console and keep it connected ,then observe console messages when device crashes (and or starts again) , an easy way to do that is with tools such as PuTTY which can save sessions too, hence you can review outputs after a period of time.
 M.
I manage it remotely.
This is the problem and therefore I lose access to it.
There is no choice... I will send a technician there.
TNX
ya follow above mentioned guide.
BB
post the full running confguration (sh run).
--> if I diable the logical VC , router stays synchonized and alive
Not sure what you mean by 'logical VC' ? What are you disabling exactly ?
