ospf over ipsec
MAHI_VYAS
Hello All,
I am trying to understand how ospf works over ipsec tunnel as OSPF used multicast to discover neighbourship and ipsec does not support OSPF.
some vendors now directly support OSPF Over ipsec with NBMA network and i am trying to understand how tunnel interface IP carried over ipsec tunnel.
1. On tunnel interface we will configure private ip and this will not be configured with phase 2 interesting traffic.
2. How ipsec will handel this tunnel interface IP rechability over wan links to form ospf neighborship.
7 Replies 7
Gre over ipsec OR ipsec over gre is different than DMVPN (NBMA).
Can you more elaborate
MHM
MAHI_VYAS
Iam just trying to understand how ipsec will handel ospf communication over point=to-point links.
As fortigate or any other firewalls does not required gre over ipsec for ospf to run.
then how traffic will be handelled for ospf neighborship.
Hello @MAHI_VYAS
When a firewall supports route-based VPN, it creates a virtual interface that acts like a normal point-to-point interface.
This enables OSPF to run natively over IPsec.
We have a P2P comunication, meaning  OSPF treat the VTI as a point-to-point interface and it uses unicast hellos to the neighbor's IP. So, no multicast is needed — OSPF can work over unicast in that point-to-point mode you see on Firewall like FortiGate.
https://docs.fortinet.com/document/fortigate/6.2.16/cookbook/632796/ospf-with-ipsec-vpn-for-network-redundancy
Best regards
First ospf always use multicast unless you use neighbor under ospf
Second
Pure ipsec support only unicast
Gre over ipsec support unicast and multicast
New ipsec (vti) support unicast and multicast
Other vendor sure use vti and hence ospf multicast can work over tunnel.
Vti different than pure ipsec in such in pure ipsec we need to config acl in crypto map in vti no need the traffic is routed via tunnel (from here come name route based vpn)
MHM
Nor do Cisco devices, for example, that support VTI.
MAHI_VYAS
M02@rt37 Thanks for sharing the link.
I have gone through the link and it works fine.
so basically we do not need to configure phase 2 interesting traffic ofr ospf over ipsec?
interesting traffic will be taken based of routing?
@MAHI_VYAS
You do not need to explicitly define OSPF or any protocol-specific traffic in the phase 2 selectors. This is because, in route-based VPN, the firewal create a VTI and handle encryption based on the routing table, not on manually defined selectors for each type of traffic. Any packet that is routed out via the tunnel interface is automatically encrypted by IPsec...
Best regards
