OSPF over PPP
sergey.klusov
Hi, i have a problem with OSPF on PPP link.
I made a pptp server on 2801:
vpdn-group pptp
! Default PPTP VPDN group
accept-dialin
protocol pptp
virtual-template 2
interface Loopback2
ip address 10.35.14.1 255.255.255.255
interface Virtual-Template2
ip unnumbered Loopback2
ip ospf network point-to-point
peer default ip address pool pptp_pool
ppp authentication chap callin vpn
ppp authorization vpn
ppp accounting vpn
router ospf 1
router-id 10.1.0.2
redistribute connected subnets
network 10.0.0.0 0.255.255.255 area 0.0.0.0
ip local pool pptp_pool 10.35.14.100 10.35.14.200
now if i connect by windows pptp client, router installs peers route and redistribute it. if i connect from mpd client, router installs peers route as well, mpd host have quagga running with same osfp settings, and they establish full adjacency, but no routes are updated on mpd host, hovewer 2801 imports ospf routes from mpd host.
if i remove "redistribute connected subnets" fom 2801, then all peer routes are removed from export AND mpd host installs all ospf routes, he got from 2801. weird.
any ideas?
sergey.klusov
After checking once again, i found that mpd host doesn't receive routes at all at this setup.
if i configure virtual-template on server with ip address 10.35.14.0 255.255.255.0
only then mpd host receives routes, but that makes connection from other host breaking routing.
