OSPF pinging failing on router.
ahmadqayyum7
I am having a problem in configuring OSPF on router R5. I am using Router-PT-Empty. I have attached my file. Kindly please take a look. The problem is that I am unable to ping the PCs attached on R5 from any other routers. While other routers are pinging each other except R5.
3 Accepted Solutions
Giuseppe Larosa
R5 has built the OSPF adjacencies with the other routes on expected links?
use
show ip ospf neighbor
is the LAN network of R5 enabled for OSPF
use
show ip ospf interface
you need a network command matching the IP address of the LAN or you need an ip ospf<pid> area <area> under the interface
Pcs have to have IP addresses within the subnet of R5's LAN interface.
Hope to help
Giuseppe
Password for the routers?
Kind Regards
Paul
luis_cordova
Hi @ahmadqayyum7 ,
In router 5 you need to declare the 192.168.6.0 network to the OSPF process.
In addition, you must correct the IP parameters of the PCs connected to that router to match the networks associated with the router interfaces.
I enclose the exercise with the corrections.
Remember to mark the correct answers as solved, because that helps other users with similar doubts.
Giuseppe Larosa
use
use
Hope to help
Giuseppe
Kind Regards
Paul
what is the password for the router ?
luis_cordova
Hi @ahmadqayyum7 ,
