OSPF priority issue
Driss BENATTOU
Level 4
Level 4
hello,
we have a 3662 router connected to both ATM Network and IP network using OSPF. the ATM network is considered the next-hop for the all ospf routes. my need is to force the routing through Ip Network using always OSPF.
Giuseppe Larosa
Hello Driss,
on the atm interface you can use
int atm x/y
ip ospf cost 1000
note:
verify current cost of routes with
sh ip route x.x.x.x
this in simple scenario can be enough unless the links are in different OSPF areas.
Hope to help
Giuseppe
hello,
thanks for reply
i have already applied it, but does not work. i noticed both static routes from both ATM and IP ? what does it mean ?
can you provide us examples, preferably your routing table
Please remember to rate useful posts, by clicking on the stars below.
