OSPF Process ID change
rmorenobb
I have a pretty straight forward change I need to make to several devices at one site; I need to change the OSPF process ID.
The site has 2 edge routers, 1 L3 switch stack that connects all 3 floor IDFs all via OSPF.
All devices are using the following OSPF config
router ospf 20
router-id 10.0.0.1 (this changes based off of device)
auto-cost reference-bandwidth 10000
area 0 authentication message-digest
passive-interface default
no passive-interface GigabitEthernet1/0/47 (this changes based off of device uplink)
default-information originate
I want to change all device(s) OSPF from process 20 to process 100
router ospf 100
interface uplink configuration looks like this on all devices
ip address 10.1.1.1 255.255.255.252
ip ospf message-digest-key 1 md5 7 072416185D0D3F175F10
ip ospf network point-to-point
ip ospf 65400 area 0
also all Vlans have OSPF
So, what I'm planning to do is script out the changes and manually apply the script.
I figured I'd start with the 3 Floor IDFs
1st floor IDF switch stack change
conf t
no router ospf 20
router ospf 100
router-id 10.2.1.1.1
no passive-interface TenGigabitEthernet1/1/1
no passive-interface TenGigabitEthernet2/1/1
int te1/1/1
no ip ospf 20 area 0
ip ospf 100 area 0
int te2/1/1
ip ospf 100 area 0
int vlan 10
ip ospf 100 area 0
end
once i have all the floors updated, then i plan to update the layer 3 core switch stack
conf t
no router ospf 20
router ospf 100
router-id 10.0.1.1
no passive-interface TenGigabitEthernet1/1/2
no passive-interface TenGigabitEthernet1/1/3
no passive-interface TenGigabitEthernet1/1/4
int range te1/1/1-4
ip ospf 100 area 0
And lastly edge routers
conf t
no router ospf 20
router ospf 100
router-id 10.4.4.4
no passive-interface GigabitEthernet0/0/0
no passive-interface GigabitEthernet0/0/1
default-information originate metric 100
int range gi0/0/0-1
ip ospf 100 area 0
end
So, one thing I think I need to add to the end of each is to clear the process ID for re convergence?
I'd like to do this remotely but not sure if I'll lose connectivity to the devices, which is why I figured I'd make the changes to the floor IDF switch stacks and then update the L3 core switch stack than the edge routers.
I'm still doing some research into this, to make this change smooth, and to not lose connectivity to any of the devices.
I'm still learning OSPF so I'm a bit hesitant with this change, for those that are knowledgeable in OSPF does this sound like the proper change?
luis_cordova
Hi @rmorenobb ,
Things to keep in mind:
In OSPF there may be convergence between devices with different process ID.
Therefore, the convergence will be lost when you delete the process (no router ospf 20).
The convergence will return when you  assign the new process to the interfaces:
int te1/1/1
no ip ospf 20 area 0 <-- this command should not be necessary, because assigning one process replaces the other
ip ospf 100 area 0
When you assign the process to the interface, the process will be created automatically, returning convergence.
Then, you can enter the specific process settings.
