Bookmark
Subscribe
4895
Difference between Dialer-Watch and Dialer-Persistent in Cellular Configuration of Cisco Router e.g 881G?
rameshprabhu
This is my first ever question, Sorry if I missed anything to Add-in to describe about my Question.
10 Replies 10
Philip D'Ath
I think "watch" causes the interface to come up if a route disappears from the routing table, and "persistent" causes the interface to always be up regardless.
Hi Philip
 First of all thanks very much for answering my question.
you mean to say for "Persistent" the dialer would always dial regardless of route check?
Yes.
Philip
 Why we need a Watch-list for Cellular Connection, Is it necessary?
Or simply the below config work?
interface Cellular0
 ip address negotiated
 ip virtual-reassembly in
 encapsulation slip
 dialer in-band
 dialer string lte
 dialer-group 1
 async mode interactive
 routing dynamic
dialer-list 1 protocol ip permit
thanks.
It may be that 3G is very expensive, you you may only want to bring the interface online when the main interface has dropped.
If may be you have a private cellular WAN, and you only want to bring it online when the route to the WAN drops on the machine interface.
I have a private cellular WAN, and its the primary and I always wanted to keep it up regardless of any route check.
In that case will the above config work?
It will stay up - as long as their is "ip" traffic flowing over it.
Here is my issue,
Does the cellular interface go down, if the router is standby or no IP traffic coming in?
Yes.  A real simple solution which I have used before is to enable NTP, and configure NTP time synchronisation to run over the interface.  Then there will always be a trickle of traffic.
Another option is to bind it to a Dialer interface and make it "permanent".
I prefer the NTP approach.  You can sync against your hub router.
Could utilize a dialer interface:
interface Cellular0
encapsulation slip
dialer in-band
dialer string lte
routing dynamic
dialer pool-member 1
interface Dialer1
dialer pool 1
dialer idle-timeout 0
dialer string lte
! Will pin the cellular connection without traffic
dialer persistent
no cdp enable
