ospf question
mguzman4158
Hi all, I have a little bit of a problem understanding the output of some ospf show commands and I was wondering if someone here can help me. Basically I don't understand why the loopback int is showing up on the output command. (see attached configuration and results of show commands)
Thank you very much in advance for your help.
Cheers!
Edison Ortiz
It's the concept of the OSPF router-ID where the router selects the highest loopback interface, if available, or the highest IP address of any of the physical interfaces as router-ID.
Here is a good tutorial:
http://www.thebryantadvantage.com/CCNACertificationExamTutorialOSPFRouterIDRID.htm
Edison Ortiz
johnspaulding
If you do a "show ip ospf neighbor" You should see that your loopback will be the router-id unless you specify. OSPF will always choose the loopback as such before any interface even if it has a higher 32 bit number. Thats why it shows up as an advertised router.
