OSPF Question
tim_roper2
I have a 6509 and a 3662 that have different paths to a remote network, 10.32.56.0/21. They are neighbors to each other; however, they don't seem to be passing any routing information about this network. Can someone help me figure out what I'm overlooking? Thanks.
6509
6509#sho ip ospf neigh
Neighbor ID Pri State Dead Time Address Interface
192.168.254.1 50 FULL/BDR 00:00:37 10.32.17.1 Vlan1
192.168.58.33 1 FULL/BDR 00:00:35 192.168.58.161 Vlan99
10.32.254.65 1 FULL/DR 00:00:37 10.32.254.65 Vlan254
6509#
6509#sho ip route | i 10.32.56.0
O IA 10.32.56.0/21 [110/6] via 192.168.58.161, 07:00:25, Vlan99
6509#
6509#sho run
router ospf 1
log-adjacency-changes
redistribute static subnets
network 10.0.0.0 0.255.255.255 area 10
network 172.16.0.0 0.0.255.255 area 10
network 192.168.0.0 0.0.255.255 area 10
6509#
3662
JH_MDF_3662#sho ip ospf neigh
192.168.58.174 100 FULL/DR 00:00:32 10.32.17.3 FastEthernet0/
192.168.58.190 0 FULL/ - 00:00:38 10.32.254.6 Serial1/0:0
10.32.254.18 0 FULL/ - 00:00:38 10.32.254.18 Serial2/0:0
192.168.58.222 0 FULL/ - 00:00:34 10.32.254.22 Serial2/2:0
192.168.58.238 0 FULL/ - 00:00:31 10.32.254.26 Multilink1
10.32.254.14 0 FULL/ - 00:00:31 10.32.254.14 Serial2/1:0
JH_MDF_3662#
JH_MDF_3662#sho ip route | i 10.32.56.0
O 10.32.56.0/21 [110/66] via 10.32.254.18, 07:12:39, Serial2/0:0
JH_MDF_3662#
JH_MDF_3662#sho run
router ospf 1
network 10.32.254.4 0.0.0.3 area 11
network 10.32.254.12 0.0.0.3 area 15
network 10.32.254.16 0.0.0.3 area 12
network 10.32.254.20 0.0.0.3 area 13
network 10.32.254.24 0.0.0.3 area 14
JH_MDF_3662#
pkhatri
Level 11
Level 11
Hi Tim,
I'm not sure I understand the exact issue you are facing. You stated that the two devices were not passing any routing info about the 10.32.56.0/21 network and yet, both have that route in their routing tables. So what exactly is the problem ?
Paresh
Sorry, I should have been more elaborate. The 3662 is pointing to 10.32.56.0 through 10.32.254.18 on one of its serial interfaces with a metric of 66. The 6509 is pointing to 10.32.56.0 through 192.168.58.161 on one of its vlans with a metric of 6. Why doesn't the 3662 point to the 6509 for the 10.32.56.0 network? Thanks.
Hi Tim,
There is a very good reason why you are seeing this behaviour. When ranking the merits of various routes, OSPF assigns preference to them in the following order:
- intra-area
- inter-area
- external type 1
- external type 2
Therefore, OSPF will always prefer intra-area routes over inter-area routes. Now, looking at the 3662, the route-type for the 10.32.56.0/21 is O (which signifies that it is an intra-area). The route on the 6509 is an IA route, which signifies that it is an inter-area route. Therefore, the metric does not even come into the calculation at all. The 3662 will always prefer the intra-area route.
Hope that helps - pls rate the post if it does.
Paresh
