OSPF Redistribution problem
jburk
Level 4
Level 4
I am having a problem redistributing static routes into OSPF from a Cisco 3825 to an Enterasys switch
Site A:
Cisco Router
Enterasys L3 Switch
ASA 5505
Site B:
Cisco Router
ASA 5505
Both sites are OSPF A0
I have a T1 Between site A and B and an ASA for internet and VPN redundancy. I am using IP SLA on the Site B end to switch to VPN if there is a T1 failure
on Site A end I am receiving the route to site B via OSPF and the routing table is populating on the Enterasys switch, I also have an 'ip route <siteb> <mask> <ip of site A asa> 150' on the Site A T1 router to add a static route via the ASA with a higher metric.
I added 'redistribute static subnets' to the OSPF process
When the T1 is up, the route to site B shows up as an OSPF route in the Site A router and L3 Enterasys switch. when I force the T1 down, the site B end switches to route over the tunnel. The static route via the VPN on Site A becomes active in the routing table, but it never shows up on the Enterasys switch, its like the Site A router never sends the update... Can someone give me some advice on how to trouble shoot this?
6 Replies 6
Giuseppe Larosa
Hello Jburk,
you need to understand if :
an external LSA type 5 is generated when primary T1 link is down on router SiteA
you can use
show ip ospf database external
to check this.
When redistributing static routes into OSPF it is very important to check how the IP next-hop of the static route is advertised in OSPF:
the IP next hop, Fowarding address in OSPF terms, has to be known as an internal route it cannot be known by another external route
so in your case you need to advertise as internal route the IP subnet between the router and the ASA, if the ASA doesn't run OSPF you can use
network
passive-interface
to achieve this
the other OSPF router if it sees a forwarding address that is not known via an internal route will not use the external LSA.
the forwarding address is a field in the LSA external data structure so the show above can give this information
if you are using redistribute connected to advertise router- ASA IP subnet it doesn't work
Hope to help
Giuseppe
Great answer!
Yes I can see this being a problem, the router interface to the switch is on 10.99.1.0/24 network and the ASA inside is on the 10.99.100.0/24 network, with the routed SVI for the 10.99.100.0 net existing on the Layer-3 switch.
So I would add another subinterface to the router to exist in this network? or move the ASA to the 10.99.1.0 network?
I did try adding a higher metric static route to the enterasys switch for the VPN but it always prefers that route even with the lower metric route being learned from the router on OSPF when T1 is up...
Hello Jburk,
thanks for your kind remarks
so it should be the entersys switch  to redistribute the static route  and not the  site A router, unless you provide a direct L3 link between router and ASA using the entersys only as a L2 switch on a new Vlan or removing SVI on existing vlan and adding a subinterface on the router.
Be careful above suggestions may have other impacts so do not implement them without double thinking!
However, I would suggest you to follow Toshi's questions to make more clear your topology and configuration.
Hope to help
Giuseppe
   Which device are you trying to apply "redistribute static subnets"?  Are you running OSPF on Enterasys switch as well?
   Please explain a bit more about your topology in detail.
Toshi
Yes OSPF on Enterasys, trying to redistribute  from site A router
   Please explain your topology in detail.
On siteA
- Enterasys and Router are running OSPF. Right?   You also configured floating routes for siteB pointing to ASA. Right?
- You don't run OSPF on ASA. Right?
On siteB
- You do the same things as siteA. Right?
Toshi
