01-22-2013 01:12 PM - edited 03-04-2019 06:48 PM
We do have multiple sites coming through MPLS to the main network. Branch office routers are configured with ospf. When it is coming through MPLS,
it is coming as external 2 route at the network. My question is that is there any way I can change those e2 route to e1 route right at the CE device at main network where MPLS network is terminating? I was thinking by creating route-map and then redistribute into the ospf process. Anybody has any idea how to tackle this? Appreciate your help.
Thanks.
01-22-2013 10:29 PM
Hi Rahman,
Yes possible at provider edge ,while redistributing from bgp to ospf process use route-map with metric-type 1.
Praveen
01-23-2013 09:52 AM
Hi Praveen,
On the PE device, service provider can do that but may be the service provider is not going to do the extra configuration on their end. I want to put the configuration on our device to control the route.
Thanks!
01-23-2013 11:08 AM
Hi Rahman.
As per my knowledge ther eis no way to metric type inbound in ospf.You can change AD if you need.
Praveen
