ospf route redistribution problem.
ajay chauhan
Level 7
Level 7
Can you explain .....I have a network running ospf ...on a boder router there is one static route configured when redistributing static route into ospf ...in neighbor routers i am not able to see the route .what could be the reason behind that.
Richard Burts
ajay
It depends somewhat on what route you are redistributing and the exact syntax that you use to redistribute. If you would post the config of the router that is doing the redistribution we would be able to give you a better answer.
One thing that explains many times when routes are not redistributed is the failure to include the subnets parameter on the ODPF redistribute statement. Did you include the subnets parameter on your redistribute statement?
Rick
Rick
Hi Rick,
Thanks for your reply don't have configuration now but trying to know what could be the reason.
