OSPF router ID change issue
olly ahmed
Can anyone help me regarding the OSPF
router-id
change issue. I made up a new interface with higher ip address by no shut command and then applied
clear ip ospf (pid) process
but it does not show the new higher IP address as
router-id
For better understanding below is the situation :
At the start of OSPF process:
R3#sh
R3#show ip int br
FastEthernet0/0 2.2.2.2 YES NVRAM up up
FastEthernet1/0 5.5.5.5 YES NVRAM up up
FastEthernet1/1 10.10.10.10 YES NVRAM administratively down down
GigabitEthernet2/0 unassigned YES NVRAM administratively down down
R3#
R3#show ip ospf
Routing Process "ospf 1" with ID 5.5.5.5
Start time: 00:00:04.952, Time elapsed: 00:00:08.500
After I make the interface 1/1 with highest ip address by no shut and clear ip ospf 1 process
R3(config)#interface fa1/1
R3(config-if)#no shut
*Jun 25 15:15:15.031: %LINK-3-UPDOWN: Interface FastEthernet1/1, changed state to up
R3(config-if)#
*Jun 25 15:15:16.031: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1/1, changed state to up
R3#clear ip ospf 1 process
Reset OSPF process? [no]: yes
R3#
*Jun 25 15:15:30.611: %OSPF-5-ADJCHG: Process 1, Nbr 2.2.2.1 on FastEthernet0/0 from FULL to DOWN, Neighbor Down: Interface down or detached
*Jun 25 15:15:30.803: %OSPF-5-ADJCHG: Process 1, Nbr 2.2.2.1 on FastEthernet0/0 from LOADING to FULL, Loading Done
R3#sh ip int br
FastEthernet1/1 10.10.10.10 YES NVRAM up up
R3#
R3#show ip ospf
Start time: 00:00:04.952, Time elapsed: 00:04:40.744
Please let me know if you know further clarification.
Peter Paluch
According to my experience, once the RID of an OSPF process has been chosen, it will not change on its own, not even if you restart the OSPF process.
Specifically, in your case, the RID of an OSPF process will not change if a new interface is added that happens to have a higher IP address than the RID. Not even clearing the OSPF process will cause it to change its RID.
To force an OSPF process to change its RID, you have to use the
router-id
command in its configuration, followed by
clear ip ospf process
command. If you then remove the
router-id
command and restart the OSPF process once again, it will elect its RID from the existing interfaces according to the usual rules.
So the behavior you have experienced is correct. You have to force OSPF manually into using a different RID; merely restarting the process is not enough.
Best regards,
Peter
Peter Paluch
router-id
router-id
Best regards,
Peter
