OSPF Routes are not showing on routing table
Dhruba pal
OSPF route is not comming on Routing table of 3925 routers.Diagram is as below
Lan1>>>>>>>>>>FW1---------------3925routerA==============3925routerB------------FW2>>>>>>>>>>Lan2
FW1 & RouterA are localy connected .RouterB & FW2 localy connected.Between 3925 router two P2P lease line UP & running.For Loadballance purpose
i have config OSPF on routerA & router B.Redistribite static & connected subnet has been configured.My problem is subnets on the Lan sides are not advertise by ospf routing table.Ospf configuration is as below.Since OSPF route is not comming on routing table i have configure default route pointed to routerB & vice versa.And configured static routes on routerA/B pointed to FW1 for Lan subnets.
Currently traffic are flowing through Default & static routes.
I would like to configure cost 1 for wan interfaces so packet will get ballance.
Please help why subnets are not comming on the routing table,On what i need to concentrate.
Hi Dhruba,
I have checked for 10.11.30.0 & 10.11.40.0 which are presented in Site B & u have distributed it in ospf .
These routes are learning through ospf in Site A.
Link ID         ADV Router      Age         Seq#       Checksum Tag
10.11.30.0      10.178.7.2      1987        0x8000005E 0x00AD9C 0
10.11.30.0      10.178.7.6      485         0x8000005F 0x0093B1 0
10.11.40.0      10.178.7.2      1987        0x8000005B 0x0045FD 0
10.11.40.0      10.178.7.6      485         0x8000005F 0x002516 0
You can remove static routes from site A & check it in routing table. It should comes in routing table if not, Pl's provide output of  show ip ospf database router 172.178.7.6 from site A
Regard's
Surya
HI Surya
Its means that from both end router, i need to remove Default & static routes.
I cant remove the routes now.I need to take downtime.& then i will revert you.
Thanks for your valuable inputs.
Dhruv
Done..Thanks Suriya.
I ma late to reply....
Thank u .....
