How to test ICMP time-exceeded
johnlloyd_13
Level 9
Level 9
hi all,
i had a client request to block ICMP request on their 1841 WAN link. i've got ACL hits for ACE 170 but not for 171.
can someone advise how to test or simulate for ICMP time-exceeded? is this TTL related and is there a DOS command or any way to produce ping packet with a less TTL count that would hit the ACL log? below is the config.
thanks in advance!
interface FastEthernet0/0
ip address 202.42.x.y 255.255.255.252
ip access-group IDS_Fastethernet0/0_in_0 in
ip access-list extended IDS_Fastethernet0/0_in_0
<SNIP>
170 deny icmp any any echo log (11189 matches)
171 deny icmp any any time-exceeded log   <<<
PC>ping 202.42.x.y
Pinging 202.42.x.y with 32 bytes of data:
Reply from 202.42.x.y: Destination net unreachable.
Ping statistics for 202.42.x.y:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 0ms, Maximum = 0ms, Average = 0ms
cadet alain
on Windows: use the -i parameter to select the TTL in the ping command
eg ping -i 2 8.8.8.8
Réponse de ********* : Durée de vie TTL expirée lors du transit.
Réponse de ********** : Durée de vie TTL expirée lors du transit.
sorry for the french output but this is all I have at my disposal here.
Regards.
Alain
hi alain,
thanks for your input. however, i wasn't able to hit any log for ACL 171.
prior to this test, i've observed ACL 171 got hits and wondered how could i replicate it.
170 deny icmp any any echo log (13441 matches)
171 deny icmp any any time-exceeded log (18254 matches)
180 permit ip any any (82617205 matches)
i've tried testing using TTL values between 5-10 but unfortunately got no hits. any further ideas?
>ping 202.42.x.y -i 8
Pinging 202.42..x.y with 32 bytes of data:
Reply from 192.169.32.182: TTL expired in transit.
>ping 202.42.x.y -i 9
#clear ip access-list counter IDS_Fastethernet0/0_in_0
170 deny icmp any any echo log (20 matches)
180 permit ip any any (11596 matches)
