OSPF routing between HUB & Spokes
karamalomari
I have the attached setup and the issue is that when a spoke tries to communicate with another spoke the communication is dropped.
The question is that when a spoke tried to communicate with another spoke, can we force the traffic from 1 spoke to another spoke go through 1 of the main HUB's. The connection that we have is point-to-multipoint and there are no direct connection between the spokes.
example: Spoke-1 --> HUB --> Spoke-2 and vise versa.
Attached is the layout along with configuration.
Please let me know how to force the traffic from all the Spokes to go 1 of the HUB's and then to another Spoke rather than trying to directly spoke --> spoke without going through the HUB's.
5 Replies 5
I don't see the config of tunnel in Spoke ?
anyway until you share config
you must sure that you see prefix of other spoke in spoke-A (example) next-hop is Hub interface, also you must sure that no phase2 & 3 of DMVPN is run
all above make traffic always between Spoke pass though Hub.
Giuseppe Larosa
Hello @karamalomari ,
if you have an E-TREE connectivity model
you need to use
ip ospf network point-to-multipoint
and
ip ospf cost at interface level can give you a way to have a primary path via links to Hub1 for example
with default configuration the OSPF type is broadcast and the spokes attempt to partecipate in DR/BDR election
you can check this using
show ip ospf interfaces on both spokes and hubs
you need also to adjust OSPF auto-refeference bandwidth or all links will have cost 1
router ospf 1
auto-reference bandwidth 1000000
You need to study OSPF in more depth.
Hope to help
Giuseppe
you could use policy routing, this would override any OSPF defined routing. The configs would be:
Spoke-01
ip access-list extended Spoke-01_Spoke-02
permit ip 172.50.10.0 0.0.0.255 172.20.10.0 0.0.0.255
permit ip 172.50.10.0 0.0.0.255 172.20.11.0 0.0.0.255
permit ip 172.50.11.0 0.0.0.255 172.20.10.0 0.0.0.255
permit ip 172.50.11.0 0.0.0.255 172.20.11.0 0.0.0.255
route-map PBR permit 10
match ip address Spoke-01_Spoke-02
set ip next-hop 172.16.150.1
interfaceGigabitEthernet0/1
policy route-map PBR
interfaceGigabitEthernet0/2
Spoke-02
ip access-list extended Spoke-02_Spoke-01
permit ip 172.20.10.0 0.0.0.255 172.50.10.0 0.0.0.255
permit ip 172.20.10.0 0.0.0.255 172.50.11.0 0.0.0.255
permit ip 172.20.11.0 0.0.0.255 172.50.10.0 0.0.0.255
permit ip 172.20.11.0 0.0.0.255 172.50.11.0 0.0.0.255
match ip address Spoke-02_Spoke-01
set ip next-hop 172.16.130.1
Hello
Your current topology isn’t optimal as the hubs won’t have any ospf adjacency to each other, however to establish communication between spoke via the hubs via ospf you need to change the network type to a network point-to-multipoint non-broadcast (NBMA) this way there is no automatic neighbor creation and you will need to specify a specific neighbor for adjacency
Lasty append a high ospf interface costing on the spoke rtrs to the less prefferd interface.
Example:
Hubs
int x/x
ip ospf network point-to-multipoint non-broadcast
router ospf  xx
neighbor <spoke 1 ip >
neighbor <spoke 2 ip >
Spokes
int x/x
int x/y  < less preffered path>
ip ospf cost 1000
Kind Regards
Paul
