OSPF routing
12pratham
we have ospf routing shutdown on the router as we no longer using it.
router ospf 10
router-id 10.1.0.2
shutdown
  network 10.1.0.2 0.0.0.0 area 0
network 10.2.0.6 0.0.0.0 area 0
passive-interface Serial0/1/0
can i just delete the config  from the router will it impact my current configuration .Please let me know
singhaam007
Level 3
Level 3
hello,
you can use
No router ospf 10  and it will terminate an OSPF routing process.
it wont effect if you are not using it.
please rate if this helps.
thanks
