Metro ethernet router config question(s)
isd_arizona
One of my clients recently moved from T1 connections to a Metro Ethernet through the local cable/internet provider (COX)
They have 4 locations
HUB: 10/10Mbps
Remote1: 3/3Mbps
Remote2: 3/3Mbps
Remote3: 3/3Mbps
We have had nothing but problems ever since switching to the new carrier.  Support calls have gone up the top engineers - they claim something's amiss with our config.  The engineer says they're seeing bursts of 40-125Mbps from HUB which is causing the problems.
Here's what I'm trying to do:
1)  Limit the connection speed from HUB to each remote office to 3Mbps and vise versa.  If we send more data than that, we run the risk of the line going down - essentially a cable modem reboot.
2)  Prioritize traffic in the following order - 1: VOIP, 2: RDP and SQL, 3: all other data
Physical layout: HUB Office>L2 Switch>Router>Cable Modem<=>COX Metro Ethernet<=>Cable Modem<Router<L2 Switch<Remote Office
I have gone through the config several times, but I fear I am missing something.  Being new to traffic shaping - i'm sure that's the case.
Here's the pertinent config from the HUB router (Cisco 2811).
class-map match-any PRIORITY
match access-group name MATCH-RDP
match protocol sqlserver
class-map match-all Estrella
match access-group name Estrella-Subnets
class-map match-all Anthem
match access-group name Anthem-Subnets
class-map match-any VOICE-MEDIA
match protocol h323
match ip dscp ef
match ip rtp 16384 16383
class-map match-all Arrowhead
match access-group name Arrowhead-Subnets
policy-map Remote_Offices
class Anthem
  shape average 2500000
class Arrowhead
class Estrella
class VOICE-MEDIA
  set ip dscp ef
  bandwidth percent 33
class PRIORITY
  set ip dscp af13
class class-default
  set ip dscp default
  bandwidth percent 10
policy-map OUTPOLICY
class class-default
  shape average 7500000
  service-policy Remote_Offices
interface FastEthernet0/0
description LAN_192.168.100.253$ES_LAN$
ip address 192.168.100.253 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
description VOICE_192.168.150.253
ip address 192.168.150.253 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/3/0
description CME
bandwidth 10240
ip address 10.0.3.1 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip route-cache flow
load-interval 30
duplex auto
speed auto
no mop enabled
service-policy output OUTPOLICY
router eigrp 1
redistribute static
network 10.0.3.0 0.0.0.7
network 192.168.100.0
network 192.168.150.0
auto-summary
ip default-gateway 192.168.100.10
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.100.10
ip route 192.168.101.0 255.255.255.0 10.0.3.3
ip route 192.168.102.0 255.255.255.0 10.0.3.4
ip route 192.168.103.0 255.255.255.0 10.0.3.2
ip route 192.168.150.0 255.255.255.0 FastEthernet0/1
ip route 192.168.151.0 255.255.255.0 10.0.3.3
ip route 192.168.152.0 255.255.255.0 10.0.3.4
ip route 192.168.153.0 255.255.255.0 10.0.3.2
ip access-list extended Anthem-Subnets
permit ip 192.168.103.0 0.0.0.255 any
permit ip 192.168.153.0 0.0.0.255 any
ip access-list extended Arrowhead-Subnets
permit ip 192.168.101.0 0.0.0.255 any
permit ip 192.168.151.0 0.0.0.255 any
ip access-list extended Estrella-Subnets
permit ip 192.168.102.0 0.0.0.255 any
permit ip 192.168.152.0 0.0.0.255 any
ip access-list extended MATCH-RDP
permit tcp any eq 3389 any
permit tcp any any eq 3389
deny   ip any any
Config from one of the remote offices (Cisco 1841)
match protocol h323
match ip dscp ef
class VOICE-MEDIA
  set ip dscp ef
  priority percent 33
class PRIORITY
  set ip dscp af13
  priority percent 33
class class-default
  set ip dscp default
class class-default
interface GigabitEthernet0/0
description CME
bandwidth 3072
ip address 10.0.3.3 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.101
description DATA VLAN 101
encapsulation dot1Q 101 native
ip address 192.168.101.253 255.255.255.0
interface GigabitEthernet0/1.151
description VOICE VLAN 151
encapsulation dot1Q 151
ip address 192.168.151.253 255.255.255.0
router eigrp 1
network 192.168.101.0
network 192.168.151.0
redistribute static
ip route 0.0.0.0 0.0.0.0 10.0.3.1
deny   ip any any
Jeff Van Houten
Level 5
Level 5
Your policy map is not setup hierarchically. Take a look at http://www.cisco.com/en/US/docs/ios/12_1t/12_1t2/feature/guide/clsbsshp.html, specifically the section titled cbwfq inside gts.
Thanks Jeff.
I actually opened a support ticket with TAC on Friday.  The tech said the config looks sound, though we're still having problems.
I read through the document and came up with a different config based on examples given.  Does the following look better?
Again, trying to limit bandwidth to 3Mbps to each remote office (estrella, arrowhead, anthem)  Overall, need to limit fa0/3/0 to 10Mpbs.
deny   ip any any
match protocol h323
match ip dscp ef
Anthem-classes
  class VOICE-MEDIA
    set ip dscp ef
  class PRIORITY
    set ip dscp af13
  class class-default
    set ip dscp default
Arrowhead-classes
  class VOICE-MEDIA
    set ip dscp ef
  class PRIORITY
    set ip dscp af13
  class class-default
    set ip dscp default
Estrella-classes
  class VOICE-MEDIA
    set ip dscp ef
  class PRIORITY
    set ip dscp af13
  class class-default
    set ip dscp default
  class class-default
  class Anthem
    service-policy anthem-classes
  class Arrowhead
    service-policy arrowhead-classes
  class Estrella
    service-policy estrella-classes
interface fa0/3/0
  service out OUTPOLICY
