OSPF Virtual Link Question
hhhax7
Studying for my ROUTE exam and had a practice question yesterday that I am kind of stuck on. Here is a picture of what the topology was like....
https://imgur.com/a/7iGH2CN
Every router ID was it's router number 4 times (R1 = 1.1.1.1, R2 = 2.2.2.2, R3 = 3.3.3.3). The issue is the loopback of R3 was not showing up in the routing table of R1. Obviously it is because R3 needs a virtual link to connect it to Area 0. So I did a show run on R3 and there was already a virtual link configured and it was conifigured as "area 10 virtual link 2.2.2.2".
Well I know that is wrong because the area you specify needs to be the transit area. So I then issued the following command.......
R3:
conf t router ospf 1 area 1 virtual link 2.2.2.2
R2:
conf t
router ospf 1
area 1 virtual link 3.3.3.3
When I did this, a "show ip ospf virtual links" told me that the virtual link was "down". The other incorrect virtual link was still in the config, so I did negated it was a "no" and got rid of it on both routers. After doing this, it made no difference, the new virtual link was still down and I could not get the loopback of R3 to show up in the routing table of R1.
Does anyone have any idea how to troubleshoot a down virutal link? I had never run into this before so was very confused. I also just set this up in GNS3 and had no issues getting it to work.
Discover the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining gifs, inspiring stories, viral videos, and so much more from users.
15 Replies 15
I cannot tell if R1 and R3 in your drawing are ABRs. Make sure the configs look like below, the VL should work then:
R1
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface GigabitEthernet0/0
description Link to R2
ip address 10.0.1.1 255.255.255.0
duplex auto
speed auto
media-type rj45
router ospf 1
router-id 1.1.1.1
area 1 virtual-link 3.3.3.3
network 1.1.1.1 0.0.0.0 area 0
network 10.0.1.0 0.0.0.255 area 1
R2
interface Loopback2
ip address 2.2.2.2 255.255.255.255
description Link to R1
ip address 10.0.1.2 255.255.255.0
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
description Link to R3
ip address 10.0.2.1 255.255.255.0
duplex auto
speed auto
media-type rj45
router ospf 1
router-id 2.2.2.2
network 2.2.2.2 0.0.0.0 area 1
network 10.0.2.0 0.0.0.255 area 1
R3
interface Loopback3
ip address 3.3.3.3 255.255.255.255
ip address 10.0.2.2 255.255.255.0
duplex auto
speed auto
media-type rj45
router ospf 1
router-id 3.3.3.3
area 1 virtual-link 1.1.1.1
network 3.3.3.3 0.0.0.0 area 10
So maybe I messed up. I see that you put on R3 "area 1 virtual-link 1.1.1.1". Is that correct? I thought you needed to put the IP of the next hop you are using to get to the backbone area. So wouldn't the command on R3 be " area 1 virtual link 2.2.2.2"? And from my understanding, it needs to be on the opposite side as well, so wouldn't R2 need "area 1 virtual like 3.3.3.3"? Or am I wrong?
test the configs I posted, it should work.
The link below has a pretty good sample configuration:
https://www.cisco.com/c/en/us/support/docs/ip/open-shortest-path-first-ospf/47866-ospfdb7.html
Don't mean to be rude but the config you posted is incorrect.
which config is incorrect, and what is incorrect ?
The virtual link config. Needs to be configured on R2 and R3
R2
R3
area 1 virtual-link 2.2.2.2
which config are you referring to ? In the one I posted, R1 and R3 are the ABRs. VL is between ABRs...
R2 and R3 are the ABRs in my topology. R1 is the backbone router
post the full running configs of all your three routers. My configs are just an example. As initially stated, I could not tell from your drawing what areas you networks belong to.
Hello
Your correct the VL needs to be configured between ABR's -  in your toplogy that would be R2 (area 0-1), R3 (area1-10)
R2
R3
As to the reason why it didnt work , Did you clear the opsf process after you had deleted the previous VL?
Kind Regards
Paul
I did not clear it. But what is weird is I deleted the original VL, the new one still didnt work (showed as down), so I put the original one back on and it came up.
Hello
It would hard to say now what could have been the issue, However I would just to confirm that your original query reagrds the VL configuration relating to your topology was indeed correct.
Kind Regards
Paul
So I have been researching and have not found a solid answer. What would you do if you has a VL showing as down? In all my studies so far for the ROUTE, I have no come across anything about it yet. This include the OCG, a class through Global Knowledge, a course on Udemy by Chris Bryant, Chris Bryant's study guide, as well as cisco docs.
