BGP configuration with Redundancy
Rw0415
Please guide to configuration of BGP with redundancy with cmd of the following topology.
dbeattie
Please be careful. If all of your sites use the same AS number, when one boundary router receives an advertisement that contains its own AS in the AS-path, it will reject the route. I would suggest at the very least, you should change your hub AS (or both of your spokes).
Hope this helps,
Dave
