OSPF weigthed load balancing
feliperodero
I would like to know if its possible to do weigthed load-balancing using OSPF.
We have 2 routers (R1 with a 3 Mbps WAN line and the second one - R2 - with 1,5 Mbps WAN line). Main one is master HSRP (R1) so it receives all packets. Question is:
is it possible to configure load-sharing but using a ratio 75% (R1) - 25% (R2) ? In this case 75% of the WAN traffic will be sent by R1 and 25% of traffic will be sent to R2 via LAN and then to the WAN.
If yes, could you please tell me how?
Thanks a lot for your help.
Kevin Dorrell
Level 10
Level 10
Unfortunately not. The only routing protocol I know that will do unequal path load balancing is EIGRP.
Kevin Dorrell
Luxembourg
