Other than Network
imnilesh
HI;
this is little outside question than Network.
I jus wanna know can any one tell me how can i find out the a perticular application bandwidth requiremnet or how much bandwidth used by that perticular application. Is there any tool by which i can justify myself or our Managemnet that the bandwidth utilisation of application is so and so.
mheusinger
Level 10
Level 10
you can use "ip nbar protocol-discovery" on a router interface to get the amount of packets and bytes transfered by a specific application.
Be aware however, that bandwidth utilization has two components:
1) bytes and throughput per transaction
2) user number and behaviour
Especially the latter is not so simple to predict in some cases.
In case you would like to get a really detailed picture about your bandwidth utilization, you might also have a look at netflow.
For further reading a good starting point would be:
www.cisco.com/go/nbar
www.cisco.com/go/netflow
Hope this helps! Please rate all posts.
Regards, Martin
