OTV ASR-1001-X : If the route is more than 2 hops away between data centers will the Overlay work
stlcbl001
I am replacing an existing 7009 with a  9500 series and ASR 1001-x. I am not able to establish the communication with the  remote data center. It is currently more that two hops away because the DCI connection is still on the 7009.
As you can see the Overlay is up, I can ping and traceroute to the other data center, but OTV is not working across the overlay.
The extended vlans cannot go across the Overlay until the peering is established.  I think I need to move the DCI circuit to the new edge router first to limit it to 1 hop across the circuit. AM I correct?
OTV01#sh otv
Overlay Interface Overlay2
 VPN name                 : None
 VPN ID                   : 1
 State                    : UP
 Fwd-capable              : No
 Fwd-ready                : No
 AED-Server               : No
 Backup AED-Server        : No
 AED Capable              : No, no overlay neighbor from other site
 Join interface(s)        : TenGigabitEthernet0/0/0.998
 Join IPv4 address        : 10.129.1.89
 Tunnel interface(s)      : Tunnel0
 Encapsulation format     : GRE/IPv4
 Site Bridge-Domain       : 998
 Capability               : Unicast-only
 Is Adjacency Server      : No
 Adj Server Configured    : Yes
 Prim/Sec Adj Svr(s)      : 10.129.1.90
OTV01#
OTV01#trace 10.128.1.4
Tracing the route to 10.128.1.4
VRF info: (vrf in name/id, vrf out name/id)
  1 10.129.1.91 1 msec 1 msec 1 msec
  2 10.129.204.1 0 msec 1 msec 0 msec
  3 10.128.1.65 4 msec 3 msec 3 msec
  4 10.128.1.4 4 msec 4 msec 3 msec
OTV01#
OTV01#sh otv adjacency
Overlay Adjacency Database for overlay 2
Hostname                       System-ID      Dest Addr       Site-ID        Up Time   State
OTV2                          10b3.d622.4780 10.129.1.90     0000.0000.0003 01:27:02  UP
OTV01#sh otv isis neighbors
Tag Overlay2:
System Id       Type Interface     IP Address      State Holdtime Circuit Id
OTV2 L1   Ov2           10.129.1.90     UP    21       OTV01-.01
Tag Site:
OTV01#
-OTV01#sh otv isis PROTO
Tag Overlay2:
IS-IS Router: Overlay2
  System Id: 10B3.D622.5300.00  IS-Type: level-1
  Manual area address(es):
        00
  Routing for area address(es):
        00
  Interfaces supported by IS-IS:
        Overlay2
Tag Site:
IS-IS Router: Site
        00
        00
        OTV-Site
OTV01#
pigallo
you have no forwarding capability enabled. Probably you missed something on the SI configuration part.
OTV01#sh otv
VPN name : None
VPN ID : 1
State : UP
Fwd-capable : No
Fwd-ready : No
AED-Server : No
can you see remote mac add information from other side?
"show otv isis database detail "
"show otv isis neighbors detail | beg 2"
