Out of band management and VRF routing
Graham Murison
We are building a new network and actually will have a management network for the first time.  Historically we are quite small and I was using inband management, but seen some decent growth of the last 5 years.
My original design won't work due to overlapping subnet.  I had vlan for this management network, but realized that the management interface is L3.  (C3850 IPServices).
sw-aggr-01#sh ip int br | incl 10.96.50
Vlan50 10.96.50.1 YES NVRAM up up
GigabitEthernet0/0 10.96.50.5 YES manual up up
sw-fl2-aggr-01#sh ip route
Gateway of last resort is 10.0.5.1 to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 10.0.5.1
10.0.0.0/8 is variably subnetted, 17 subnets, 4 masks
C 10.0.5.0/30 is directly connected, Vlan5
L 10.0.5.2/32 is directly connected, Vlan5
S 10.96.50.0/24 is directly connected, Vlan50
sw-fl2-aggr-01#sh ip route vrf Mgmt-vrf
Routing Table: Mgmt-vrf
10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 10.96.50.0/24 is directly connected, GigabitEthernet0/0
L 10.96.50.5/32 is directly connected, GigabitEthernet0/0
I am trying to figure of the best way to route to this through our firewall to audit traffic. Anything outside 10.96.50.0/24 goes through the firewall.
My only thought at this point is moving all switch management function to another Vlan (Vlan 55 for example)
I want to keep the data and management plains separate as a best practice if I am able to design that way.
Any other suggestions from the gurus?
0 Replies 0
