ASA Firewall Question
Iloveyou
The firewall is configured with sub interfaces on a single physical interface.
How do I enable inter vlan routing between them? (Prefer restrict to subnets)
Users cannot ping outside. How to solve? (Prefer restrict to subnets)
9 Replies 9
Blue_Bird
Here is the sample configuration....
ASA Version 8.6(1)2
hostname ciscoasa
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface GigabitEthernet0/0
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet0/1
 description ### To SW01 F0/1 Trunk ###
 no nameif
 no security-level
 no ip address
interface GigabitEthernet0/1.10
 vlan 10
 nameif CORP
 security-level 100
 ip address 192.168.10.254 255.255.255.0
interface GigabitEthernet0/1.20
 vlan 20
 nameif DMZ
 security-level 50
 ip address 192.168.20.254 255.255.255.0
interface GigabitEthernet0/2
 shutdown
 no nameif
 no security-level
 no ip address
Best regards
******* If This Helps, Please Rate *******
How do I enable inter vlan routing between them? (Prefer restrict to subnets) dont need any config by default asa will do inter vlan between two subinterface immediately after give IP to it
You need
Inspection icmp
NATing from both Inside subinterface into outside
Blue_Bird
Here is the complete  sample configuration....The ip addressing scheme you can change according to your requirement...
ASA Version 8.4(2)
hostname Mario-Guitar-Shop-HQ
names
nameif outside
security-level 0
ip address 50.0.0.1 255.255.255.248
interface GigabitEthernet1
nameif inside
security-level 100
ip address 10.20.10.1 255.255.255.0
interface GigabitEthernet1.2
vlan 2
nameif vlan2
security-level 100
ip address 10.0.0.1 255.255.255.0
interface GigabitEthernet1.3
vlan 3
nameif vlan3
security-level 100
interface GigabitEthernet2
nameif wireless
security-level 100
ip address 192.168.10.1 255.255.255.0
interface GigabitEthernet3
shutdown
no nameif
no security-level
no ip address
ftp mode passive
same-security-traffic permit intra-interface
pager lines 24
mtu outside 1500
mtu inside 1500
mtu vlan2 1500
mtu vlan3 1500
mtu wireless 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd lease 7200
dhcpd address 10.20.10.11-10.20.10.100 inside
dhcpd dns 10.20.10.1 interface inside
dhcpd enable inside
dhcpd address 192.168.10.10-192.168.10.100 wireless
dhcpd dns 192.168.10.1 interface wireless
dhcpd enable wireless
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
no active
destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
destination address email callhome@cisco.com
destination transport-method http
subscribe-to-alert-group diagnostic
subscribe-to-alert-group environment
subscribe-to-alert-group inventory periodic monthly
subscribe-to-alert-group configuration periodic monthly
subscribe-to-alert-group telemetry periodic daily
crashinfo save disable
Cryptochecksum:2c391b206dfd8073446c7b05db3d6b73
Best regards
Can you highlight which command is for the ping and which command is for the in ter vlan routing?
The primary interface should not have any IP addressing or name configured:
nameif inside
security-level 100
ip address x.x.x.x x.x.x.x
Now if you are going to use sub-interfaces you need a switch (with a trunk interface) or router (with the same sub interfaces) facing the firewall.
In order to make it work, you need to create ACLs on the firewall, example:
access-list VLAN-2-IN extended permit icmp any any echo
access-list VLAN-2-IN extended permit icmp any any echo-reply
access-list VLAN-2-IN extended permit ip any any
access-list VLAN-3-IN extended permit icmp any any echo
access-list VLAN-3-IN extended permit icmp any any echo-reply
access-list VLAN-3-IN extended permit ip any any
Then apply them to the access-group like we do on the routers.
access-group VLAN-2-IN in interface vlan2
access-group VLAN-3-IN in interface vlan3
Remember security level 100 is full protection so you need explicitly allow the access, in other words using ACLs.
Best regards
I should make myself clear.
The sub interfaces are on the asa firewall itself. So what is the command?
And which command for the intervkan routing
for inter vlan you dont need any command, only you must sure the subinterface is UP.
for ping what is security level of both sub interface ?
if it same then as @paul driver mention you need
same-security-traffic permit inter-interface
and enable inspection icmp
if the secuirty level different then you need only
Hello
Apply the following:
Kind Regards
Paul
