Outbound Load Balancing
network_dude
Hey Everyone,
I have 4 T1s which I am load balancing via ip cef per destination. That seems to be working for for my receiving, but my transfer does not seem to be load balancing. Please see my "sh int sum" below:
nterface IHQ IQD OHQ OQD RXBS RXPS TXBS TXPS TRTL
* FastEthernet0/0 0 0 0 0 254000 434 5604000 478 0
FastEthernet0/1 0 0 0 0 0 0 0 0 0
* Serial0/1/0:0 0 0 0 0 1409000 125 0 0 0
* Serial0/2/0:0 0 0 0 0 1411000 125 0 0 0
* Serial0/3/0:0 0 0 0 0 1407000 125 215000 430 0
* Serial0/3/1:0 0 0 0 0 1407000 125 1000 4 0
Is there anyway I can load balance my outbound traffic?
Thank you,
Scott
6 Replies 6
Harold Ritter
Level 12
Level 12
Scott,
Are you using a default static route to each of the 4 serial interfaces? If so, could you provide us with a "show ip cef 0.0.0.0" internal.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Yes, I am using a default route to each...please see ip cef below:
#show ip cef 0.0.0.0 internal
0.0.0.0/32, version 1, epoch 0, receive
Thank you.
Sorry, the command should have been "show ip cef 0.0.0.0 0.0.0.0 internal".
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Here you go...
#show ip cef 0.0.0.0 0.0.0.0 internal
0.0.0.0/0, version 89, epoch 0, per-destination sharing
0 packets, 0 bytes
via xxx.xxx.xxx.1, 0 dependencies, recursive
traffic share 1
next hop xxx.xxx.xxx.1, Serial0/3/1:0 via xxx.xxx.xxx.1/32
valid adjacency
via xxx.xxx.xxx.2, 0 dependencies, recursive
traffic share 1
next hop xxx.xxx.xxx.2, Serial0/3/0:0 via xxx.xxx.xxx.2/32
valid adjacency
via xxx.xxx.xxx.3, 0 dependencies, recursive
traffic share 1
next hop xxx.xxx.xxx.3, Serial0/2/0:0 via xxx.xxx.xxx.3/32
valid adjacency
via xxx.xxx.xxx.4, 0 dependencies, recursive
traffic share 1
next hop xxx.xxx.xxx.4, Serial0/1/0:0 via xxx.xxx.xxx.4/32
valid adjacency
0 packets, 0 bytes switched through the prefix
tmstats: external 0 packets, 0 bytes
internal 0 packets, 0 bytes
Load distribution: 0 1 2 3 0 1 2 3 0 1 2 3 0 1 2 3 (refcount 1)
Hash OK Interface Address Packets
1 Y Serial0/3/1:0 point2point 0
2 Y Serial0/3/0:0 point2point 0
3 Y Serial0/2/0:0 point2point 0
4 Y Serial0/1/0:0 point2point 0
5 Y Serial0/3/1:0 point2point 0
6 Y Serial0/3/0:0 point2point 0
7 Y Serial0/2/0:0 point2point 0
8 Y Serial0/1/0:0 point2point 0
9 Y Serial0/3/1:0 point2point 0
10 Y Serial0/3/0:0 point2point 0
11 Y Serial0/2/0:0 point2point 0
12 Y Serial0/1/0:0 point2point 0
13 Y Serial0/3/1:0 point2point 0
14 Y Serial0/3/0:0 point2point 0
15 Y Serial0/2/0:0 point2point 0
16 Y Serial0/1/0:0 point2point 0
refcount 3285, covered prefixes:
xxx.xxx.xxx.1/30
xxx.xxx.xxx.2/30
255.255.255.255/32
224.0.0.0/4
xxx.xxx.xxx.xxx/29
xxx.xxx.xxx.xxx/30
xxx.xxx.xxx.xxx/30
0.0.0.0/32
This output shows that per destination (which is really per flow, meaning src and dest IP address are considered) will take place. It is possible that loadsharing will not make use of all interfaces equally if you only have a few flows. The probability of equal loadsharing usually increases when the number of flows is higher.
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
That makes sense...I'll generate more traffic for further testing.
Thank you for your help!
