Outer Switches in Enterprise Internet Edge Design
sumesh.nair
Hi Folks
Seek to know what purpose do the outer switches(Layer two switches between the Internet Router and Firewall) serve as depicted in the
http://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/WAN_and_MAN/Internet_Edge/InterEdgeOver.html#wp72110
Know that it acts as a Layer 2 Boundary but what functionality/design aspect would one lose/suffer if the firewall and the router are connected back to back
Sumesh
johnd2310
Level 8
Level 8
If you read down that documents you find the following under Routing and Switching section:
"As illustrated in Figure 7, the outer switches implement a single Layer 2 segment or VLAN that provides connectivity between the firewalls and the edge routers. This VLAN is the firewall's outside segment. As firewall failover requires all firewall interfaces to be Layer 2 adjacent, the outside VLAN needs to be carried by both outer switches."
Highlighted section would be one of the reasons you have the outer switches.
John
**Please rate posts you find helpful**
Not sure about that John coz there are designs/implementations in which firewall can be connected back to back with the edge routers.If I am not wrong I can still have all the interfaces as layer 2 adjacent without necessarily having outer switches
