output drops o gig int
Sanjay Shaw
Am not finding the resolution to my infrastucture and getting output drops. Sw1 is connected Sw2 as below stated
Please find the conf:
Sw 2 3750 conf:
interface GigabitEthernet1/0/46
no switchport
ip address 172.16.100.81 255.255.255.248
interface GigabitEthernet1/0/47
no switchport
ip address 10.72.250.200 255.255.255.0
standby 0 ip 10.72.250.210
interface GigabitEthernet1/0/48
no switchport
ip address 172.16.100.74 255.255.255.248
GigabitEthernet1/0/46 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 1cdf.0f89.83c1 (bia 1cdf.0f89.83c1)
  Description: ****  ****
  Internet address is 172.16.100.81/29
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
     reliability 255/255, txload 25/255, rxload 1/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:01, output 00:00:02, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 5206270
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute output rate 10045000 bits/sec, 906 packets/sec
     23445839 packets input, 13362109858 bytes, 0 no buffer
     Received 4243815 broadcasts (0 IP multicasts)
     0 watchdog, 4243682 multicast, 0 pause input
     4016088554 packets output, 5526970378766 bytes, 0 underruns
GigabitEthernet1/0/47 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 1cdf.0f89.83c2 (bia 1cdf.0f89.83c2)
  Internet address is 10.72.250.200/24
     reliability 255/255, txload 2/255, rxload 3/255
  Last input 00:00:00, output 00:00:01, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 1090
  5 minute input rate 1402000 bits/sec, 567 packets/sec
  5 minute output rate 898000 bits/sec, 1297 packets/sec
     6542350264 packets input, 2288468001575 bytes, 0 no buffer
     Received 10436050 broadcasts (0 IP multicasts)
     0 watchdog, 10291195 multicast, 0 pause input
     12679777185 packets output, 1605428478319 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
GigabitEthernet1/0/48 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 1cdf.0f89.83c3 (bia 1cdf.0f89.83c3)
  Description: **** *****
  Internet address is 172.16.100.74/29
  Last input 00:00:02, output 00:00:02, output hang never
     8690674 packets input, 880185867 bytes, 0 no buffer
     Received 4257355 broadcasts (0 IP multicasts)
     0 watchdog, 4257337 multicast, 0 pause input
     131343910 packets output, 31366608834 bytes, 0 underruns
sw 2950 ;
interface FastEthernet0/22
description c3750-sw1-pt46
switchport access vlan 781
switchport mode access
spanning-tree portfast
interface FastEthernet0/23
description c3750-sw1-pt48
switchport access vlan 780
interface FastEthernet0/24
description c3750-sw1-pt47
switchport access vlan 790
FastEthernet0/22 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is 000e.83db.c3d6 (bia 000e.83db.c3d6)
  Description: c3750-sw1-pt46
  MTU 1500 bytes, BW 100000 Kbit, DLY 1000 usec,
     reliability 255/255, txload 1/255, rxload 8/255
  input flow-control is off, output flow-control is off
  5 minute input rate 3269000 bits/sec, 263 packets/sec
  5 minute output rate 2000 bits/sec, 3 packets/sec
     397114259 packets input, 1378072999 bytes, 0 no buffer
     Received 183700 broadcasts (0 multicast)
     0 watchdog, 183346 multicast, 0 pause input
     224748880 packets output, 1847373962 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
FastEthernet0/23 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is 000e.83db.c3d7 (bia 000e.83db.c3d7)
  Description: c3750-sw1-pt48
  5 minute input rate 135000 bits/sec, 75 packets/sec
     155456069 packets input, 3381363039 bytes, 0 no buffer
     Received 164405 broadcasts (0 multicast)
     0 watchdog, 164394 multicast, 0 pause input
     25738128 packets output, 1455071616 bytes, 0 underruns
FastEthernet0/24 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is 000e.83db.c3d8 (bia 000e.83db.c3d8)
  Description: c3750-sw1-pt47
     reliability 255/255, txload 7/255, rxload 4/255
  Last input 00:00:00, output 00:00:00, output hang never
  5 minute input rate 1945000 bits/sec, 2007 packets/sec
  5 minute output rate 2984000 bits/sec, 1106 packets/sec
     2336656579 packets input, 1916806953 bytes, 0 no buffer
     Received 4113631 broadcasts (0 multicast)
     0 watchdog, 4112935 multicast, 0 pause input
     3636496844 packets output, 1822207913 bytes, 0 underruns
Switch1   2950
InterfaceConfVlaConnected to
22vlan 781SW 2-C3750X-Gig   1/0/46
23vlan 780SW2-C3750X-Gig 1/0/48
2410.72.250.78vlan 790SW2-C3750X-Gig 1/0/47
Kind reply would be helpful.
5 Replies 5
Leo Laohoo
1.  You connect a switch to another switch and you enable portfast?  Are you serious???
2.  Why is your setup like this?  You could've just link them all together and form an etherchannel or use one link and allow dot1q trunking and specify the VLAN to carry across the link.
Output drops happen when the interface (3750) trying to push the traffic starts to drop the payload because the remote end (2950) can't handle the inbound traffic.
Thanks for the reply.
To update you I would like to add few more poits.
We have two 3750 Switch and two 2950 Switch which are connected vice versa ports as stated above .
Can I hv any soln on the present architecture to prevent the output drops on 3750. I understand ur point that the 2950 switch is not able to handle the incoming packets.Please reply what are the conf changes require to hv a soln to this problem
Removing  spanning tree port fast command can prevent the drops.
Note: I do not want to change the architecture.
Thanks in advance.
Hi sanjay,
in addition to leo's reply,your n/w design is not in good architect.why don't you create SVI for each subnet instead of creating route port.as leo suggested make etherchannel or single trunk b'n SWs to carry multiple vlan informations
pls rate if hepfull
shehin.pm
This line does NOT make any sense with the next line below.
Output drops, as explained in my first post, happens when the 3750 interface is shoving as much data as it can downstream to your 2950 but the 2950's downstream port can no longer handle the traffic. THIS is your prolblem.
In my personal and humble opinion, someone did a very terrible job with your so-called network. You have three links to both switches. All three links are not in etherchannel. Now THIS is the problem and the solution to your problem. If you convert and configure etherchannel then things might get better.
So you see, you need to change the "architecture".  Trying to solve your output drops without addressing the underlying problem is like driving g0lf buggy in the highway and not doing anything about it.
Thanks Leo and Shehin I do agree your points and will do as per your suggestion. Will discuss if required.
