04-28-2016 12:29 PM - edited 03-05-2019 03:54 AM
hi,
i have a 7600 with WS-X6748-GE-TX. I have a port-cannel (4x1G) to cmts, i´m seeing a lot of Total output drops. This drops i see in each interface of the channel. The total traffic on channel is 1,2 gbps, so the traffic for interface is 300 Mbps (peak hour).
When i see the queueing, all the drops are in queue 1 (cos 0).
What can i do to eliminate the drops ?
#sh int port-channel 121 | in rate
Queueing strategy: fifo
30 second input rate 42881000 bits/sec, 25824 packets/sec
30 second output rate 607609000 bits/sec, 60330 packets/
#sh int Gi3/35 | in rate
5 minute input rate 10067000 bits/sec, 6387 packets/sec
5 minute output rate 167940000 bits/sec, 16241 packets/sec
Temuco_7609#
sh queueing interface Gi3/35
WRR bandwidth ratios: 100[queue 1] 150[queue 2] 200[queue 3]
queue-limit ratios: 50[queue 1] 20[queue 2] 15[queue 3] 15[Pri Queue]
Packets dropped on Transmit:
queue dropped [cos-map]
1 7032114 [0 1 ]
2 0 [2 3 4 ]
3 0 [6 7 ]
4 0 [5 ]
regards,
Carlos
04-29-2016 06:27 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
How to try to remediate the drops depends on the cause of the congestion. Increasing Q1's bandwidth or queue-limit ratios might decrease its drops although at the chance of increasing drops in other queues.
You say you have a 4x port channel - how's the distribution load across the ports? If uneven, perhaps there's a better hash algorithm for your traffic.
Lastly, sometime you need more bandwidth or a "better" line card. (Not sure you'll find much better than a 6748 for gig usage.)
04-29-2016 11:17 AM
hi,
in the channel the distribution across all ports is uniform.
The interfaces are not congested and I always see drops.
regards,
Carlos
04-29-2016 11:27 AM
Disclaimer
Posting
If there were no congestion, there shouldn't be drops.
What often happens, microbursts cause millisecond congestion, which may cause drops, but multi-second monitoring doesn't see these.
04-29-2016 12:31 PM
04-30-2016 06:02 AM
Disclaimer
Posting
The number of discards a second, alone, means nothing. You need to compare to the volume of traffic at the same time.
