output drops other than by RED
paul amaral
Level 4
Level 4
if using RED/WRED for congestion what else would cause output drops. i ask because i have a higher number of total output drops than I do with RED drops. Basically why im I not seeing the other drops, supposedly i have 719 drops but only 421 by RED, what caused the other drops.
Also in this case with late drops I'm assuming this is the typical congested output queue and WRED removed all non important packets.
thanks for your time, Paul
Serial8/1/1 is up, line protocol is up
  Hardware is PODS3 Serial
  MTU 4470 bytes, BW 44210 Kbit, DLY 200 usec,
     reliability 255/255, txload 40/255, rxload 38/255
  Encapsulation PPP, crc 16, loopback not set
Input queue: 0/75/0/7 (size/max/drops/flushes); Total output drops: 719
  Queueing strategy: Class-based queueing
  Output queue: 0/40 (size/max)
  30 second input rate 6702000 bits/sec, 1753 packets/sec
  30 second output rate 6978000 bits/sec, 1797 packets/sec
     50404534 packets input, 26804686540 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
              0 parity
     9722 input errors, 9710 CRC, 0 frame, 3 overrun, 0 ignored, 9 abort
     53762996 packets output, 29151563718 bytes, 0 underruns
     421 packets late drop, 543133 bytes late drop
     0 output errors, 0 applique, 0 interface resets
     2 carrier transitions
sh int xx random
Class 0 queue size 0
       packets output 44386011, wred drops 421, nobuffer drops 0
WRED: queue average 0, weight 1/512, max available buffers 4973
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Might be wred drops don't include RED tail drops or non-RED queue drops.
What's show policy interface stats look like?
The show policy-map int xxx shows only random drops that are 421 (less than total output drops) and tail drops at zero. what constitutes and non RED queue drop, i would think on a 44 meg serial interface doing an average of 10 megs a congestion mechanism like RED would drop all packets before the queue got congested, i guess that maybe im getting some spikes in bandwidth that RED is not keeping up!?
Paul
Disclaimer
Posting
I'm not positive WRED always replaces the original queue with its own queue.  It might help if you posted the show policy interfaces stats.
I think i figured out why i was seeing more drops reported with sh int xxx than with show policy-map int xxx. Looking at the router log i notice that the interface bounce a couple of times and this must of dropped all packets in the outgoing queue that were no WRED dropped.
