Output Drops won't stop incrementing
Chad Stachowicz
Level 6
Level 6
   So I am a voice guy by nature but having an issue that is constantly affecting our UCCE which we believe is related to a point to point link between our clusters.
The point to point link is required by UCCE in order to put high priority traffic.  We noticed one set of servers one the link was constantly having delayed messages.  Some discovery let us to find that the output drops on both the Multilink interface and the Policy map is incrementing continuously.  The link is barely in use by our traffic monitor, and these servers should cause a relatively low amount of traffic in general.  Can someone please help me figure out what to look for, or if something we have configured could be causing out problems?  I have posted relevent snippets below...   We have 4 links in the bundle, all T1's
CONFIG
class-map match-any VMEDHIGH
match access-group name MDS_DMP_High
class-map match-any VDEFAULT
match access-group name The_Rest
class-map match-any VMEDLOW
match access-group name Med_Low
class-map match-any VHIGH
match access-group name UDP_Heartbeat
policy-map NewOne
class VHIGH
    priority 24
class VMEDHIGH
    bandwidth percent 87
    queue-limit 224 packets
class VMEDLOW
    bandwidth percent 10
    queue-limit 96 packets
class VDEFAULT
    bandwidth percent 1
buffers small permanent 800
buffers small max-free 1300
buffers small min-free 100
buffers middle permanent 700
buffers middle max-free 1000
buffers middle min-free 100
interface Multilink123
description Verizon Business Multilink Circuit
ip address 192.168.0.1 255.255.255.252
ip flow ingress
load-interval 30
no peer neighbor-route
ppp chap hostname 01524705-1658985
ppp multilink
ppp multilink links minimum 1
ppp multilink group 123
ppp multilink fragment disable
max-reserved-bandwidth 99
service-policy output NewOne
interface GigabitEthernet0/0
description Connection to Voice Private Network
ip address 192.168.10.2 255.255.255.0
ip flow ingress
load-interval 30
delay 10000
duplex full
speed 100
standby 1 ip 192.168.10.1
standby 1 priority 120
standby 1 preempt
standby 1 track 1 decrement 10
interface GigabitEthernet0/1
description connection to mia0mgr2960sw1 via Vlan 10 for Management
ip address 10.6.10.77 255.255.255.0
load-interval 30
duplex full
speed 100
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:0
description MGBKVHBP0001 Local LEC ID 60HCGS440396SB
no ip address
encapsulation ppp
load-interval 30
ppp quality 90
ppp multilink
interface Serial0/0/1:0
description MGBKVHBW0001 Local LEC ID 60HCGS440444SB
no ip address
encapsulation ppp
load-interval 30
shutdown
ppp quality 90
ppp multilink
interface Serial0/0/2:0
description MGBKVHB50001 Local LEC ID 60HCGS440428SB
no ip address
encapsulation ppp
load-interval 30
ppp quality 90
ppp multilink
interface Serial0/0/3:0
description MGBKVHB60001 Local LEC ID 60HCGS440427SB
no ip address
encapsulation ppp
load-interval 30
ppp quality 90
ppp multilink
INT LOG
Multilink123 is up, line protocol is up
  Hardware is multilink group interface
  Description: Verizon Business Multilink Circuit
  Internet address is 192.168.0.1/30
  MTU 1500 bytes, BW 4608 Kbit/sec, DLY 20000 usec,
     reliability 255/255, txload 34/255, rxload 49/255
  Encapsulation PPP, LCP Open, multilink Open
  Open: IPCP, CDPCP, loopback not set
  Keepalive set (10 sec)
  DTR is pulsed for 2 seconds on reset
  Last input 00:00:00, output never, output hang never
  Last clearing of "show interface" counters 1w1d
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 4365388
  Queueing strategy: Class-based queueing
  Output queue: 0/1000/0 (size/max total/drops)
  30 second input rate 891000 bits/sec, 694 packets/sec
  30 second output rate 626000 bits/sec, 730 packets/sec
     399677327 packets input, 1614936420 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     435367479 packets output, 138243357 bytes, 0 underruns
     0 unknown protocol drops
     0 output buffer failures, 0
policy-map log
  Service-policy output: NewOne
    queue stats for all priority classes:
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/0/0
      (pkts output/bytes output) 50157990/1705371626
    Class-map: VHIGH (match-any)
      50157990 packets, 1705371660 bytes
      30 second offered rate 18000 bps, drop rate 0 bps
      Match: access-group name UDP_Heartbeat
        50157989 packets, 1705371660 bytes
        30 second rate 18000 bps
      Priority: 24 kbps, burst bytes 1500, b/w exceed drops: 0
    Class-map: VMEDHIGH (match-any)
      370321773 packets, 34267772294 bytes
      30 second offered rate 593000 bps, drop rate 4000 bps
      Match: access-group name MDS_DMP_High
        370321768 packets, 34267772344 bytes
        30 second rate 593000 bps
      Queueing
      queue limit 224 packets
      (queue depth/total drops/no-buffer drops) 0/4365868/0
      (pkts output/bytes output) 365955900/34043099450
      bandwidth 87% (4008 kbps)
    Class-map: VMEDLOW (match-any)
      16489550 packets, 3699211519 bytes
      30 second offered rate 82000 bps, drop rate 0 bps
      Match: access-group name Med_Low
        30 second rate 82000 bps
      Queueing
      queue limit 96 packets
      (pkts output/bytes output) 16489550/3699203279
      bandwidth 10% (460 kbps)
    Class-map: VDEFAULT (match-any)
      2784014 packets, 156213164 bytes
      30 second offered rate 1000 bps, drop rate 0 bps
      Match: access-group name The_Rest
        30 second rate 1000 bps
      Queueing
      (pkts output/bytes output) 2784014/156494681
      bandwidth 1% (46 kbps)
    Class-map: class-default (match-any)
      12287 packets, 4398746 bytes
      30 second offered rate 0 bps, drop rate 0 bps
      Match: any
      (pkts output/bytes output) 12287/4398746
Thanks so much!
Chad
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
From looking at what you've posted, looks like burst tail drops.
Without knowing more about the nature of the traffic, can't truly recommend a solution.
Obvious/typical solutions include providing more bandwidth or increasing the class queue depth even further, but percentage of drops might be decreased (and performance improved) by decreasing queue depth and/or using RED.
Joseph,
  This is real-time, mission critical traffic, which is probably alot of packets, with not a lot of size.  Can you explain what increasing queue depth means?  Is that the queue-limit 224 I am seeing?  I don't believe its bandwidth related, because a lot of other servers ride on this link, and have no issues, these UCCE servers are running some specials things that are probably generating alot more 'bursty' traffic.
I am not the data guy here, but was just getting some input.  Would you mind perhaps showing what a configuration of increased queue depth is, and if there is any other show commands which might provide more information / confirmation of this?
Thanks again, upvoted!
Chad
Disclaimer
Posting
If real-time you might want to move to LLQ for this traffic.  Is this traffic part of VMEDHIGH or VHIGH now?
Yes, the 224, see below.  You might try 512.
policy-map NewOne
class VHIGH
    priority 24
class VMEDHIGH
class VMEDLOW
class VDEFAULT
    bandwidth percent 1
      Queueing
In the show policy, when there appears to be active drops, see if you see a large queues depths.
i.e.
      Queueing
The above only shows zero, but looking for non-zero values.  If traffic is very bursty, might take several snapshots to catch.
What's show buffers look like?  What's the device and its IOS version?
Disclaimer
Posting
BTW, if your critical traffic is already in the LLQ, but you're seeing occasional delays, that might be cause of interface transmission FIFO queues.  The latter might be mitigated by using tx-ring-limit 3 on each serial interface.
