Outside NAT to internal machines - 2 ISPs
Darren Spezio
I have 2 ISP links,  69.74.x.x and a second new one that I just added 108.162.x.x to our Cisco 2900 to increase our overall speed, which is working.
Can the outside NAT connections that are on the 69.74.x.x  be affected by adding the new link? I have a few users reporting that they can't get into internal machines from outside that have NAT through the ASA starting about the time I added this link, while others have no issue at all.
NAT on ASA = 69.74.x.x > 10.8.x.x
interface GigabitEthernet0/0
description Outside-LightPath
ip address 173.251.x.x 255.255.255.252 duplex auto speed auto ! interface
GigabitEthernet0/1
description To Firewall
ip address 69.74.x.x 255.255.255.240
IP nat inside
interface GigabitEthernet0/2
description To Cable WAN
108.162.x.x 255.255.255.252
IP nat outside
access-list 50 permit 69.74.x.x 255.255.255.240
IP nat inside source list 50 interface 108.162.x.x 255.255.255.252
overload duplex auto speed auto
! ip forward-protocol N ! no ip http server no ip http secure-server ip http timeout-policy idle 60 life 86400 requests 10000 !
ip route 0.0.0.0 0.0.0.0 173.251.x.x
ip route 0.0.0.0 0.0.0.0 108.162.x.x
44 Replies 44
It should have cleared any entries since you made the change.
Just do a "sh ip nat translations" and see what it says.
Jon
Pro Inside global          Inside local        Outside local              Outside global
udp 108.1x.146:328    69.x.211:328       17.x.125:123             17.x125:123
So only the 69.x.x.211 IP which is what you want.
Are the users still unable to access the servers.
If they try then run that command again to make sure there are no translations for server IPs.
Jon
how long will the internet be disrupted once I run clear ip nat translations * ?
You don't need to if that is all that is in the translation table because there are no 69.x.x.x server IPs.
You only need to clear translations for any 69.x.x.x server IPs not the 69.x.x.211 IP because that is just used for internal users to get to the internet.
I am not sure where we are with this at the moment ie. have users tried to connect to servers since you modified the acl and is it still not working.
And is general internet access for internal users working ?
Jon
I ran the command a bunch of times and they are all on 69.x.211.               Everyone inside is able to get out to the internet without any issues. The only thing is that some outside users are not able to get to the inside servers.
Well it is not a NAT issue anymore.
I suspect the ones that aren't working are the ones going via the backup link, perhaps causing a lot of out of order packets etc.
I would suggest trying the PBR solution so that all traffic to and from the servers uses the primary link.
Jon
Okay I will have to try PBR tomorrow - I will keep you posted
Thank you Jon for all your help
Since adding "access-list 50 permit host 62.x.x.211" all of our e-mail notifications from our IT help system and scan to e-mail stopped working both using aspmx.l.google.com - Very strange
Jon any thoughts on this?
Sorry, I missed your latest reply.
I don't know why the change has broken connectivity.
All that change does it to stop traffic from the servers being translated to 10.182.x.x IPs and that should not break anything.
There is obviously something else going on that isn't clear at the moment.
Can you post the full router configuration ?
Jon
Attached - I still have not had the chance to config the PBR after core hours.
There is nothing obviously wrong with your router configuration.
All I can say is what I have said before ie. using that acl simply means servers that are translated to other 69.x.x.x IPs are not translated again to 10.182.x.x IPs which is what you want.
Unless your backup ISP is filtering on the source IP address which if they are then that would break things.
Jon
I removed the secondary ip route 0.0.0.0 0.0.0.0 108.x.x.x and now the e-mail alerts and scan to email are working again, they both use aspmx.l.google.com - I'm a little confused as to what could be happening when that route is in place.
How are the users connecting to the servers ?
Jon
