Override IGP metric on BGP Route selection?
Lost & Found
Level 2
Level 2
I have BGP VPNV4 peer router ,1st is Edge RTR and 2nd Route Reflector.
We are using IGP underneath. Now, Im received routes from Route reflector then install to Edge RTRs VRF but when I look at the bgp table, Router metric is changed to IGP metric. BGP inherited the IGP metric.
EGDE RTR#sh bgp vpnv4 unicast vrf test 10.22.23.0/24
Paths: (2 available, best #1, table test)
Not advertised to any peer
(65 64 651) 655 650 354 1, imported path from xxxx:10.122.203.0/24
13.21.22.7 (metric 65) from 3.3.3.11 (3.3.3.11) <<<--------
Origin IGP, metric 0, localpref 100, valid, confed-internal, best
Extended Community: xxxxxx
mpls labels in/out nolabel/2408
(65 64 651) 655 1 1 1, imported path from xxxxxxx
13.16.4.11 (metric 70) from 3.3.3.11 (3.3.3.11) <<<-------- I want to prefer this route
Extended Community: xxxxxxx
mpls labels in/out nolabel/10066
What is the best solution to use C2 as nexthop from Edge router??
Harold Ritter
The igp metric is evaluated only if all previous steps in the BGP best path selection process are equals.
https://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/13753-25.html
You could change the local pref higher on the second path to prefer it over the first one.
