P2P blocking
I have 2821 router and ASA 5520 installed in my university. Task of router is just to pull internet bandwidth, while security ad control is performed by the ASA. Students usually use bypass proxy sites and P2P downloaders to download unnecessary and irrelevant things, thus choking the bandwidth. Can anybody tell me a solution for:
1) URL blocking on 2821 router or ASA 5520.
2) P2P blocking on 2821 router or ASA 5520.
andrew.prince
Level 10
Level 10
Below are some config examples for url & p2p blocking in the ASA
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080940e04.shtml
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080940c5a.shtml
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00808c38a6.shtml
However if you have a proxy server and your students are bypassing it - the solution is simple.
Confiugure the ASA to ONLY allow the Proxy server to access internet content HTTP/HTTPS services. Obviously allow other critical services, Email, DNS, SMTP etc.
HTH>
Thank you very much for being helpful. I'll definitely try to use this solution and get back to you ASAP.
np - glad to help
