PA-MC-T3= card question
aiannaccone
Greetings,
I have done a bunch of research in trying to re-use an old card/router for testing our new MPLS link. I have a 45m DS3 and was wondering if the PA-MC-T3= card will work un-channelized. I have tried the "no channelized" command under the controller to no avail. I believe that the card only works for channelized T1's. Anyone have any ideas?
Thanks!
Richard Michael
No you cannot run PA-MC-T3 in unchannelized mode. Only MC-2T3+ does unchannelized.
Ricky Micky
*Rate useful posts
