2800 default licence
mirehteshamali
we have isr 2800 series router . i just want to check by default without licence how many  easy vpn and ssl vpn's we can have . we have a security image installed .
thanks
Rozsa Illes
For EZVPN clients, you do not need a separate licence. It is based on how many tunnels are supported on the platforms. The information I found was: with AIM module, it is max: 1500.
For SSL VPN, 10 users are supported without licence. With licence, it is 100 for 2811 and 2821 and 150 for 2851.
Here are the links I used for reference:
http://www.cisco.com/en/US/partner/prod/collateral/iosswrel/ps6537/ps6586/ps6657/product_data_sheet0900aecd80405e25_ps5854_Products_Data_Sheet.html
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6586/ps6635/ps6659/data_sheet_c78-457320.html
Warm Regards,
Rose
great investment !!
thanks for clarification !
