Packet drop about 50% - Identical segment with NAT + VRF
g114112118s
Indeed it's an odd design and we are trying to avoid it. however without going into reasoning. Let me quickly summarize the topology and problem we are facing.
We have a few hosts and each needs identical IP setup. hosts can remain in separate vlan and intervlan routing is NOT required.
As example: Four vlan configured and with uplink trunk port to the router.
Router has also four vrf with four subinterfaces.
Each subinterfaces has NAT enabled
non vrf outgoing interface has also NAT enabled
source static NAT enabled for each vrf
default route configurated for each vrf
reverse-route configured for each vrf
Please read 8.8.8.8 as random public IP and we can control only two routers and a switch in the diagram.
Config in the diagram tested on a real platform but noticed the about 50% pack drop.
chrihussey
Could be wrong but I don't think you need the static routes to the 192.168.x.0 /24 in VRF Router A. The NAT process should be doing the translation and sending the packets to the original IP.
Hope this helps
PS - Really not too odd of a design in that it explains the purpose and capabilities of VRFs pretty well.
Giuseppe Larosa
Hello g114112118s,
I have a question in the network diagram you show that you ping 8.8.8.8 from a device that looks like a router DMN because I see a prompt ending in #.
This specific router is acting as one of the Pcs in the four VRFs in the diagram, or it is the router where all the NAT configuration and VRF is performed?
I agree it is a strange design, but your configuration looks like correct. In production you should use 4 different NAT pools for scalability.
Hope to help
Giuseppe
chrihussey
Hope this helps
