Packet drop on GRE Tunnel
nasr.khan
When traffic is passed via the GRE Tunnels packets are dropped.As the bandwidth are unequal I am using EIGRP
Currently running EIGRP between Tunnel routers and OSPF between VPN Router to Core.  Physical links are ok, no error on interfaces.
If I run only tunnel at sales_office then no drops. load sharing is required on two tunnels. i have plugged the configuration to the post.
Once drop concern are fixed will add IPSEC to it.
please do input
8 Replies 8
nasr.khan
Is it possible some ios doesnt work well with EIGRP loadbalancing.
VPN router1 at DC : Version 12.4(9)T7   ( advanceEnterprise )
VPN router2 at DC : Version 12.4(9)T7   ( advanceEnterprise )
VPN router at SO : Version 12.4(24)T2   ( advanceEnterprise )
Please support
I would request you to apply the tweaks  on the tunnel interface and see the results.
IP MTU 1400
IP Tcp adjust−mss 1300
There are issues with IOS .
But we need to correct the configuration part first.
In my experience I would say not to use unequal cost load balancing with GRE as it will create lot of out of order packets.
Also I am directing you to this link
https://supportforums.cisco.com/message/3030859#3030859
Hello Parthiban
Adding these command didnt help
IP MTU 1400
when you say not to use unequal  cost load balancing with GRE
what I need to eleminate from my configuration.
If unequal cost load balancing is an Know Issue then what is the other major reason to move to EIGRP over OSPF
Hello Experts
I am still stuck on this, help please.
What type of load balancing is running on EIGRP.
Is it per packet or per destination?
I have tested GRE over Ipsec with EIGRP ...two 100 MBPS links with per packet load balancing with 0 Drops.
can you share your sample working config.
Hello Netpro
What is recommended for unequal loadbalancing ( per packet / per destination ) with EIGRP
I am stuck on EIGRP part.
