11-20-2020 01:26 AM
Hi!
I am getting the following error when dialing a number from Cisco IP Phone 7960. Calls went to voice mail.
debug ip packet detailed output is below:
s=179.1.10.200 (GigabitEthernet1/2), d=200.73.73.15, len 72, dispose udp.noport
UDP src=13181, dst=16751
Asterisk VOIP Server IP Address: 179.1.10.200. Located in Cloud
Router WAN IP Address: 200.73.73.15
Cisco 6509-E with SUP720-3B
IOS Versioin: s72033-adventerprise_wan-mz.122-33.SXJ.bin"
11-20-2020 02:59 PM
hard to say why this happens. Can you provide a topology diagram showing what devices are in your network, and how they are connected ?
11-23-2020 12:08 AM - edited 11-23-2020 12:10 AM
Hi!
Please check the network diagram.
Internet works fine. IP Phone is getting registered with the server. But while dialing calls went to voicemail. I think SIP Is working but RTP is not working.
I am using SVIs Vlan 300 for data and Vlan 400 for Voice. Int vlan 300 and 400 are NAT inside interfaces.
Gi 1/4 is configured as Trunk-Interface and connected with Access Layer Switch.
Gi 1/2 is configured with IP address 200.73.73.15/29 and Gateway is 200.73.73.16/29. Nat Outside Interface.
Default route 0.0.0.0 0.0.0.0 200.73.73.16
11-24-2020 03:25 AM
I recall there are a few NAT commands around related to RTP and NAT. Not sure which one is applicable in your case, and if the 6509 supports them at all, but try to configure the below:
ip nat service allow-h323-even-rtp-ports
ip nat service allow-sip-even-rtp-ports
ip nat service allow-skinny-even-rtp-ports
11-29-2020 10:42 PM
These commands are not supported in my case.
11-30-2020 02:32 AM - edited 11-30-2020 02:33 AM
Also I have captured packets from wireshark via SPAN.
When dialing 200 from extension 200. I am getting the following output. And calls went to Voice Mail.
11-30-2020 04:10 AM
--> When dialing 200 from extension 200
What are you actually dialing ? What is connected to extension 200 ? Do any calls at all (to other extensions) connect correctly ?
11-24-2020 03:12 AM
Its unlikely to get a disengage signal for RTP noty flowing, you probably best off to plug phone into the 6500 and run a span session to see what signalling is happening (use wireshark), also can the phone dial out? is it just the one phone with asterisks you are using? has this worked before? connect second phone and see if the two can ring each other.
11-30-2020 04:52 AM
I have tried with SPAN session. And and I am able to dial outbound numbers. But inbound are not working.
Getting an error of 404 when captured packets via wireshark.
No ip nat service sip udp 5060 command is also not supported.
Please help. 😞
11-30-2020 04:55 AM
I have tried the following IOS but still the same issue.
s72033-adventerprisek9_wan-mz.122-33.SXI10.bin
s72033-adventerprisek9_wan-mz.122-33.SXJ1.bin
s72033-advipservicesk9_wan-mz.122-33.SXI6.bin
s72033-adventerprisek9_wan-mz.122-18.SXF4.bin
12-03-2020 12:24 AM
I am able to dial out external numbers. But not able to receive inbound calls. Also I have tried after 2 IP Phones with extension number 100 and 200 but I am not able to dial other extension too. When I try to dial 100 from extension 200 instead of ringing it went to Voice Mail.
Please advise.
