Hi All,
I have been over on CLN and someone suggested i posted here, which TBH i thought was the same site but obviously not! there is another cool site to post and respond to problems!!
I have a problem with one of our customers where they have a SIP trunk over a leased line and they are getting ~10% packet loss on the inbound direction with most calls. Occasionally the packet loss jumps up to 50% and then becomes unusable which obviously causes strain on them as they rely heavily on their phones for their line of business.
The 50% packet loss is very intermittent and is not being caused by any devices on site or the egress interface which has a leased line attached. The leased line is 10mbps and is nowhere near being congested. they utilise about 1/3 of the line most of the time which carries Voice and data. The Firewall device limits the Data throughput so it does not affect the voice.
My thoughts are that this is a problem with the return traffic from the SIP provider which takes a different route to the sent traffic and that the SIP provider needs to investigate further as they need to follow the path to see if there are any issues or any potential load balancing issues along the way (this may explain the 50% packeet loss?)? QUESTION: DOES ANY ONE HAVE ANY OTHER THOUGHTS ON HOW I COULD APPROACH THIS OR WHERE THE PROBLEM IS? I know this is the $100 question but just looking for different approaches or thoughts really.
Below is a very 'loose' diagram of what the network topology is like on site (customer) and also shows what is in between the site and the SIP provider.
![SIP trunk problem.jpg](/legacyfs/online/legacy/8/6/6/82668-SIP%20trunk%20problem.jpg)
The config of the Cisco 1941 is below which shows that it is a standard rotuer with nothing fancy on it that would cause a problem.
version 15.2
hostname CISCO_1941
boot-start-marker
boot-end-marker
logging buffered 51200 informational
no aaa new-model
no ipv6 cef
ip cef
username admin privilege 15 secret PASSWORD
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description LEASED_LINE
bandwidth 10240
ip address X.X.X.53 255.255.255.252
duplex full
speed 100
no cdp enable
interface GigabitEthernet0/1
description
ip address X.X.X.62 255.255.255.248
duplex auto
speed auto
no cdp enable
interface ATM0/0/0
no ip address
shutdown
no atm ilmi-keepalive
pvc 0/38
encapsulation aal5mux ppp dialer
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 X.X.X.54
access-list 23 permit ME
access-list 23 permit MY REMOTE SITE
access-list 23 permit SITES SUBNET
access-list 23 permit MY HOME
control-plane
banner motd ^C
Unauthorized access prohibited
^C
line con 0
exec-timeout 0 0
logging synchronous
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
ntp server 130.88.200.4
end
