Packet loss while ping between local routers
khuuleo
Hi all,
I have an issue about my local routers. And i don't know, why did it happen. My system as below.
I have packet lost while ping from Router A to Router B, but ping from Router A to Router C does not have packet lost.
I tried changing the router with another router, and changing port switch between Router B and Router C, change MTU .... but the results have not changed.
But i tried changing Router B with my computer, there was packet lost.
This is my configure on port g0/0 of router A and f0/0 of router B. (The configure on SW is default)
C2901:
interface GigabitEthernet0/1
ip address 101.53.X.X 255.255.255.252 secondary
ip address 202.151.Y.Y 255.255.255.248
ip nat inside
ip virtual-reassembly in
standby 1 ip 202.151.Z.Z
standby 1 preempt
standby 1 track 1 decrement 10
duplex auto
speed auto
C1921
interface FastEthernet0/0
description PORT_WAN
ip nat outside
ip tcp adjust-mss 1400
speed auto
full-duplex
So cause of this issus and how can i fix it?
Many thanks.
10 Replies 10
nurbol555
Hello! it seems you have on router C2901 one ip address for Router B and secondary address for Router C. Why you don't try configure your connect from Router A to router B and C with sub interface? and use for evry connect between router A and B, A and C separate configuration
Hi nurbol555,
I have 2 range IP Public, so i use 1 for connect from Router A to Router C and 4 other device. And use the remaining ip for Router A and Router B.
I think issue not on my IP because I has changed Router B with my laptop and hasn't packets lost.
It seems you trying connect from router B to address 202.151.Y.Y 255.255.255.248, maybe your HSRP on port conflicting when you connecting to this address, try delete HSRP on port (standby config)
I connect from Router B to address 101.53.X.X 255.255.255.252, and this address don't run HSRP. I also tryed changing IP 101.53.X.X with IP 192.168.100.1/24 but it still has packets lost.
Try delete HSRP on port, if it's not working can we see all configuration?
check for CPU utilization as well with the 'show proc cpu' command...
SOHAN HEGDE
Have  you try to change duplex settings on router B, it seems it is configured to FULL, can you change duplex to auto.
Hi SOHAN HEGDE,
at first, duplex setings on router B is default, So i tryed changing duplex FULL, but result hasn't changed.
Thanks.
in addition to the other posts, what is the uptime of the SG300 ? Have you tried to reboot it ? In the port settings of the SG300 (Port Management --> Port Settings), you can enable autonegotiation of flow control, you might want to give that a try.
Also, the default MTU and MSS settings should be sufficient, so remove the 'ip tcp adjust-mss 1400' from the FastEthernet interface.
Hi Georg Pauwen,
The uptime of the SG300 many days. I can't reboot it, because in behind switch SG300 is my system, and it can't disconnect.
Also, the function auto negotiation is enable on all port.
I have tested 2 cases, MTU and MSS are default, and changed different parameter (as above is 1400). Packetloss at both cases above.
Thanks.
