Packet size limit for IP?
Neuromancer
I was wondering if there is a limit to the amount of payload that IP imposes? Or is it strictly the frame payload limit (ethernet) that limits the amount of data per packet?
Thanks for the links. So it looks like layer 3 doesn't explicitly impose a payload limitation. The MTU comes from the layer 2 technology being used. Then of course you have the UDP max segment size (~65K). Thanks again!
