Packet Tracer: access-group out seems not working
KirDoan
Hi everyone, I can't figure out how this ACL do not apply to the outside interface of the ASA, I want to deny all the traffic that is not NATed to outside network, so I created this network test the command but it just doesn't work.
access-list OUTSIDE-DENY-OUT extended deny ip 172.16.1.0 255.255.255.0 any
access-group OUTSIDE-DENY-OUT out interface outside
In Simulation mode, it doesn't even bother to check the ACL criteria, so I thought this was a bug or am I missing something here? I'm a student and new to networking, any help would be greatly appreciated!
Also, I have attached the pkt file.
7 Replies 7
ACL is correct' did you initiate traffic from inside to outside ?
Yes, I did try to ping using the private IP address (172.16.1.2/24) from inside network
This is ip of inside interface?
172.16.1.2/24 is the one of the hosts of inside network, the inside interface on the ASA is 172.16.1.1/24. The outside interface ip is 1.0.0.1/8
Ok' can you share asa config here  I dont have pkt so I can not open zip file.
Sure, here is the asa config:
ASA Version 9.6(1)
hostname ciscoasa
names
interface GigabitEthernet1/1
nameif inside
security-level 100
ip address 172.16.1.1 255.255.255.0
interface GigabitEthernet1/2
nameif outside
security-level 0
ip address 1.0.0.1 255.0.0.0
interface GigabitEthernet1/3
no nameif
no security-level
no ip address
shutdown
interface GigabitEthernet1/4
no nameif
no security-level
no ip address
shutdown
interface GigabitEthernet1/5
no nameif
no security-level
no ip address
shutdown
interface GigabitEthernet1/6
no nameif
no security-level
no ip address
shutdown
interface GigabitEthernet1/7
no nameif
no security-level
no ip address
shutdown
interface GigabitEthernet1/8
no nameif
no security-level
no ip address
shutdown
interface Management1/1
management-only
no nameif
no security-level
no ip address
shutdown
access-list OUTSIDE-PERMIT-IN extended permit icmp any any echo
access-list OUTSIDE-PERMIT-IN extended permit icmp any any echo-reply
access-list OUTSIDE-PERMIT-IN extended permit icmp any any unreachable
access-group OUTSIDE-PERMIT-IN in interface outside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect icmp
inspect tftp
service-policy global_policy global
telnet timeout 5
ssh timeout 5
Did you see the config reply? I can't see it in the replies for some reason so here is the txt file instead
