BGP As Path Prepending Neighbor AS
nwekechampion
Level 3
Level 3
Hey guys,
Just a quick one, what would be the effect of prepending neighbors AS in BGP update? Would it achieve the same results as prepending my own AS to Neighbor?
Your neighbor will drop it' this one of loop prevent bgp use' if router see it as in as path attribute it assume loop and drop prefix.
No
If you do as prepend in your router then you effect inbound traffic.
If your neighbor do as prepend the  it will effect your outbound traffic.
Thanks I meant what if I did AS prepend with my nieghbors AS instead of my AS?
Thank you
