Packet Tracer Activity Wizard - Redistribution of RIP into OSPF
scheffler1
I am setting up a Packettracer-Test, where I want my students to redistribute RIP routes into an OSPF Process.
The Activity Wizard shows me the following for the Router that has both Routing Protocols enabled:
      OSPF -> Process ID -> Redistribution, and I set a check-mark at RIP.
However, when I run the test, the condition never becomes true. What am I doing wrong? The network is running fine. Everything works as expected, only Packettracer thinks that the Activity is not completed...
Thomas
Martin L
show run from a router doing Redistribution;  Double-check ur wording, missing something;  do u ahve 100% completion mark? PT activity "test" may not work ok. Note those activities do not work 100% especially if converted from previous version of PT to new PT;  we had similar issues;
You can attach PT file here but it must be in a zip format;
Also check CLN community PT and CCNA forums at
https://learningnetwork.cisco.com/s/communities
https://learningnetwork.cisco.com/s/topic/0TO3i0000008jYHGAY/ccna-certification-community
https://learningnetwork.cisco.com/s/topic/0TO6e000000WEorGAG/packet-tracer
Regards, ML
**Please Rate All Helpful Responses **
Hello Martin,
sorry, it has taking me a while to come back to this topic.
I am not able to reach a 100% completion mark. The test was adapted from a previous one, I added the redistribution part.
Everything else is working as expected and the network is fully configured: the students should set up an OSPF process on router HTW2 and redistribute the RIP route:
"HTW2 has already configured RIP routing. Import the RIP routes into the OSPF process and also include the subnet information."
I have included the PT file for reference. Any hint on how I could get PT to recognize the redistribution command would be very welcome.
Best regards, Thomas
