Packet Tracer Help
cw0110
%IPPHONE-6-REG_ALARM: 24: Name=SEP001D452D50BD Load= SCCP41.8-3-3SR2S Last=Phone-Reg-Rej
My 2811 Router prints this error message in the CLI as if in an infinite loop. I haven't been able to find much about this error, and and I'm not sure how to fix this problem. All of VOIP Phones are receiving IP Addresses, but they randomly drop them. It seems as though this is causing excessive collisions. Any advice would be greatly appreiated!
here is the revised file. I think it will take a while before all phones are properly registered, due to the sheer number.
6 Replies 6
post your zipped Packet Tracer project (.pkt) file...
you need to change the MAC addresses configured under the ephones to match those that are actually on Vlan 70. If you hover the mouse over an IP Phone, you will see 'Vlan 70' and a MAC address, that is the MAC address that goes under the respective ephone.
Thank you!! I've done that, and the error message has gone away. However, all of my phones seem to be frozen and displaying "Configuring CM List". Any suggestions there? Sorry, I'm very new to PT.
Thank you so much!!
